Low Tire Pressure Light
Old Oct 24, 2011 | 03:39 PM
50th ann's Avatar
50th ann
The low pressure light came on. I checked the tires and corrected the pressures. Then I tried to reset the light as the owners manual recommended.
The light will not go out. I have reset it several times. Training the valves as Ford calls it but no luck. The light stays on. Any ideas?
Old Oct 24, 2011 | 06:59 PM
ohboy44's Avatar
ohboy44
All that's needed to turn the light out is drive it more then 20 mph for 2 minutes after filling the tires to the proper psi.
Old Oct 24, 2011 | 07:34 PM
50th ann's Avatar
50th ann
Thanks
I"ll give it a try in the morning
Thanks for the Help
Old Oct 25, 2011 | 08:23 AM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
Also something else that might help, if the system on the F-150 is the same as on a Toyota 4-runner, the spare tire also has a low pressure sensor on it. The light will come on if the pressure is low on the spare.
Old Oct 25, 2011 | 09:40 AM
shotgunz's Avatar
shotgunz
The spare does not have a TP sensor.
BobbyJPhotos
2009 - 2014 F150
15
Dec 10, 2016 05:13 PM
EMTFF722
6.7L Power Stroke Diesel
25
Mar 10, 2015 05:28 AM
whiteywhip
17
Jan 17, 2013 09:50 AM
90pioneer
Nov 30, 2011 11:54 AM
El Jim
1983 - 2012 Ranger & B-Series
Jul 5, 2010 08:47 PM
