Holley Sniper on 400
So Merry Christmas to me, I just ordered the Holley Sniper system and the Dual Sync distributor setup. It is supposed to be here next week. I got tired of jacking with the carb, but I had intended to make the switch at the start of the build. My Carb has not been working right since I added the E4OD because it needed a throttle position sensor and it affected the choke high idle. I could never get the set screw to work right. It would either idle crazy high or act like it didn't have a choke at all. Dialing the timing in wasn't terrible, but I really like the ability to set everything from base timing to max advance on the keypad instead of using a wrench. I'm geeking out about how cool this system is. I ordered the kit with the returnless pump. I also found a universal fuel float at tanks inc that I will be putting in since I have the 38 gal tank and hate that I never know exactly how much fuel I have. But that's just an annoyance. So, I will do a write up with lots of pics if anyone is interested.
A good write up, yea its Fitech but might help some where. https://www.ford-trucks.com/forums/1...n-77-f150.html
Links to good stuff. https://www.ford-trucks.com/forums/1...-guidance.html
Like Holley Sniper on a 77 F250 400 https://classicbroncos.com/forums/sh...d.php?t=293349
Duel tanks and EFI help, just in case. https://www.ford-trucks.com/forums/1...-question.html
Looking fwd to this tech write up for sure.
It's a really, really simple setup. I have the 2-barrel "2300" Sniper on my 351M. It's rather roughly done because I have so many other issues to resolve, but starting, running, and idling are not among them! The hardest part of the swap was figuring out fuel supply - I'm running on a temporary tank in the bed for now because both my tanks have dino juice from roughly the same period in them. Also, the coolant temperature probe leads are just a little too short for connecting to the OEM temperature sending location in the block. I had to extend mine but that was not hard. To power up the "pink" ignition +12Vdc wire, I used a relay and snipped off the white and red plug from my Duraspark box which was pretty much junk. I think I have a schematic somewhere on my phone.
One thing - if you do buy a kit, get it from EFISystemPro. Chris is super helpful.
If you intend to keep both tanks, then you need a swirl pot type pump. I had 2 tanks but opted for the 38 gallon one. Now the front fuel tank door goes to nowhere. Edelbrock has a pretty nice pump for the swirl pot. I've downloaded the PDF install guide to start planning a bit. I'm not quite sure about a few things but I'll figure it out. I currently have an HEI Dizzy so I've got the tach wire and the hot. The dual sync seems a bit more involved but doesn't look complicated. I rewired the truck and now I'm going to be adding a ton of wires so It may take some doing to keep everything clean. On the plus side, since I'm doing this, I will have almost no need for vacuum as the only thing connected to vacuum will be my AC dash controls and the PCV valve. So I will plug off everything to eliminate those pesky vacuum leaks I get when those rubber caps split at inconvenient times. I also bought a nice MSD ratcheting plug wire crimper so I'm hoping to cut down my spark plug wires and make it much neater. I also need to break out my Baumann controller book and see how I get the TPS input signal for it. Nothing too complicated. I think the most tedious part will be mounting the fuel pump and my new sending unit.
I was thinking about those, but I'm going a different direction, I spec'ed out another electric fuel tank valve from newer Fords that have EFI and dual tanks. They have ports for switching the return lines as well. my tanks are good, but they need to come out anyway because I'm having some issues with the original sending units. I bought a couple of these fuel tank valves at wrecking yards as I found them.
I run my dual tanks, but I have done things a little differently. I installed a 38 gal aft tank, with a Tanks Inc pump, and I have my midship tank routed back to the aft tank with just a small electric fuel pump. It acts as a reserve to the large tank, and I can even use it while driving to replenish the aft tank while on the road. Works perfectly and gives me a 57 gallon range. The dash switch still operates to show the fuel levels in each tank.
David
David
I'm probably going to go the same route as rougeriver - run one primary tank and use a transfer pump for the second. Not worth the hassle of managing a dual return line.
TX - I went with the Hyperspark setup and it was too simple to set up. Perhaps an option? Makes for a more complete install when the computer controls the timing.
I ordered the Hyperspark dizzy also. I really like the ability to tune it with the touch screen. I noticed the truck would come alive when I set base timing at 12, but the mechanical advance got it pinging at higher rpm. With this, I can set base timing at 12 and max advance I can lower to 30 or 31 to stay out of pinging range but still have better lower speed performance. Who knows maybe with the proper A/F ratio it wont ping at 32. Lots of possibilities without having to take a wrench and timing light to it to make an adjustment. I will have all my parts here on Tuesday so I'm going to probably be wrenching on Christmas day.
I’m at 400hp/500tq so the 2 barrel is just below my power rating so I ordered the 4 barrel. I’ve got the Edelbrock performer dual plane intake and I have a 1” phenolic spacer that has the 4 holes drilled rather than the single plane version.
