IPR % question
Old Dec 19, 2019 | 10:41 AM
Motohead911's Avatar
Motohead911
IPR % question
I am just trying to figure out if what I am seeing on my values is normal, or if I should be concerned. I did the head gaskets about 2 months ago and everything is running good, except for my radiator leak. Anyways, I have noticed when I let the truck sit for more than a few hours my IPR % gets to almost 85% on cranking. It is just a quick spike then it drops back down to like around 40% on a cold start up. When it is warm it idles around 23%. If it has been run for a while and I shut it off for like 20 to 30 minutes the value only gets up to 40% or so.
I dont have any crank no start situations. When cold it starts in about 3 seconds and warm 2 seconds.
I guess am i worrying about nothing?
Old Dec 19, 2019 | 10:49 AM
bismic's Avatar
bismic
I wouldn't worry a lot about it.
After your quick spike in IPR %, it shouldn't go above 40%. Sounds like you are right there. The warm idle number looks good to me.
How cold is it when you say "3 seconds for a cold start"? Mine starts quicker than that in cold weather, but the coldest weather here is around 30 degrees.
T diesel
6.2L V8
45
Jan 9, 2017 05:11 PM
F33lmywrath
Sep 18, 2016 09:42 AM
Yahiko
Jan 13, 2013 04:32 PM
RussellF
Jan 16, 2009 10:26 AM
CounterMaker
Feb 4, 2007 10:55 AM
