WTF is that noise?
Old Dec 18, 2019 | 06:01 PM
hjartland's Avatar
hjartland
WTF is that noise?
OK. Now my truck is making this noise. About 5 seconds in. It happens twice. It's kind of a whirring sound.
You feel it through the pedal. Happens on smooth & rough roads. In neutral or drive. Regardless of throttle.
What do you hear? (Not the zipper or blinker sounds) BTW it is 10°F & plenty of snow and ice.
https://youtu.be/6uHPoVkmYPA
Old Dec 18, 2019 | 06:15 PM
Binkowski's Avatar
Binkowski
I mainly hear the zipper and blinker noise, but the most common whirring noise is the fan clutch that has gone bad and the fan is engaged constantly. Sounds like a loud vacuum cleaner. Try moving the fan when the engine is off and cool. If it won't move...time to replace.
Old Dec 18, 2019 | 07:01 PM
hjartland's Avatar
hjartland
will it
Will do. But could it generate enough vibration. To be clearly felr. Through the gas pedal?
Old Dec 18, 2019 | 07:23 PM
torq'ta 5 8's Avatar
torq'ta 5 8
make sure mud(dried) not stuck in fins, fins broke, blades bent/broke/chunked
Old Dec 19, 2019 | 02:40 AM
Ken Blythen's Avatar
Ken Blythen
I don't know about through the gas pedal specifically, but I had an '83 F150 with a recently rebuilt 302 (3000 miles); the previous owner reused the old fan clutch & the engine vibrated inconsistently.
The fan was able to move sideways about an 1/8" or so due to the worn clutch hub, causing the vibration - but sometimes it sat almost central.....so no vibration.
Old Dec 19, 2019 | 08:59 AM
hjartland's Avatar
hjartland
ok
I'll check it out.
Old Dec 19, 2019 | 01:13 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
If you are suspecting the fan/clutch causing some kind of vibration you MIGHT be able to remove them and drive with them off for a short time (so as to not overheat your engine) and see if by eliminating them that gets rid of this mystery noise/vibration thing. Again I don't recommend doing it for too long because of the risk of overheating but if it's for a few minutes after you cold soak it (and in colder weather) you'd probably be ok.
Old Dec 19, 2019 | 04:55 PM
hjartland's Avatar
hjartland
nice
Nice idea. Will keep it in mind.
Old Dec 20, 2019 | 05:45 PM
hjartland's Avatar
hjartland
free
The fan moves fairly freely when engine is cold.
Old Dec 21, 2019 | 03:56 PM
hjartland's Avatar
hjartland
ABS
ABS may be the issue. It sounds like the LH side. Given the facr it has rear wheel ABS. Maybe that is firing at random times??
Jayslow
1997 - 2003 F150
Sep 4, 2014 07:39 PM
nix4x4
Jun 27, 2013 05:58 AM
rdg2009
Nov 1, 2009 06:19 AM
jam105
6.4L Power Stroke Diesel
Sep 4, 2007 07:37 PM
ROFFL
13
Jun 5, 2003 05:10 PM
