ZF5 fluid question
Old Dec 18, 2019 | 10:28 AM
obsxl's Avatar
obsxl
ZF5 fluid question
hey guys, new member here. So I’ve got a 1994 f250 with the ZF5, and the 3rd gear synchro is a little worn. When it’s warm outside it shifts ok but when it’s cold out it won’t even go into 3rd. once the tranny warms up it will shift. I’ve heard good things about Redline MTL and how it can make worn synchros shift better, but I’ve also heard it makes cold weather shifting harder, is this true? Should I put Redline in my tranny or good atf or what? it’s got atf in it now but I don’t know what kind
Old Dec 18, 2019 | 01:15 PM
jas88's Avatar
jas88
You might as well try it, it's not going to hurt anything.
Old Dec 18, 2019 | 01:26 PM
ford390gashog's Avatar
ford390gashog
Redline MTL and MT85 50/50 is what's in mine, that advice was from this forum a d I have had no issues since. Also overfilled by half a quart for the gear noise.
Old Dec 18, 2019 | 02:25 PM
obsxl's Avatar
obsxl
yeah but I just hate to spend $60-$70 on new fluid if it isn’t going to help cold shifting
Old Dec 18, 2019 | 02:27 PM
obsxl's Avatar
obsxl
were you having problems shifting before? did it help? I haven’t heard of that solution before...
Old Dec 18, 2019 | 07:23 PM
ford390gashog
Mixing the two gets you just slightly thicker than the mercon ATF. Keep in mind gear oils and ATF are rated differently and a oil like MTL is actually very similar to mercon and is actually around 6.1 CST viscosity. It also satisfies the following from the Redline tech files.
Red Line MTL is classified as a 75W/80W gear lubricant satisfying the API Service requirements of GL-3 and GL-4. MTL also satisfies motor oil viscosities SAE 5W/10W/30, and the viscosity requirements for ATFs. MT-90 is a 75W90 GL-4 and also satisfies motor oil viscosities SAE 10w40, 15w40.
There is lots of information about mixing the lubes online and from Redline directly. Look over at BITOG.
Old Dec 21, 2019 | 09:02 AM
frank5079's Avatar
frank5079
Earlier this year I drained my M5OD gearbox and used Synchromesh manual transmission fluid instead. My gearbox shifts so much better and I can honestly say I wished I had done it sooner and that I won't be going back to ATF.
Old Dec 21, 2019 | 05:11 PM
Diesel_Brad's Avatar
Diesel_Brad
I "wasted" my money on the redline fluid. Didn't do anything. But a rebuild fixed the sycnronizer problem
Old Dec 21, 2019 | 07:39 PM
00t444e's Avatar
00t444e
Pennzoil Syncromesh is a great fluid to use in the ZF5 and ZF6 transmissions, much better than atf.
Old Dec 23, 2019 | 12:25 AM
TobyB's Avatar
TobyB
I've used MTL for several decades- it works fine in an ATF transmission.
D6 is also good- maybe a little thinner.
But neither will fix a worn- out synchro or countershaft bearing.
t
Big-Red-Lariat
Escape & Escape Hybrid
Jun 26, 2018 05:35 PM
Selder
Dec 8, 2008 07:09 PM
JeremyJ
1983 - 2012 Ranger & B-Series
Apr 30, 2007 11:12 PM
rverg
Jul 7, 2004 08:54 AM
1990Fordf150v8
Oct 22, 2003 11:28 AM
