No fire
Old Dec 21, 2019 | 06:25 PM
Bmac49's Avatar
Bmac49
No fire
I'm new to the Ford forums and I need some desperate help... I have a 92 f250 that drive daily and one day I stop at a store and turned the truck off and got back in to leave and it wouldn't start thought it was the fuel pump in the rear tank so I changed it and it still wouldn't start. Looked at every fuse that I could possibly find and found nothing ... Changed out the relay for the fuel pump and it started up no problem and so I drove it home went to work the next morning no problem until I went to leave work an hour later and it wouldn't start wiggled relays , wires even kicked it afew times and still nothing ... Got it home and fuel pump was not coming on but it will crank did some other things and got power to fuel pump but now I have no spark and I've checked ever possible thing that I know to check but I'm still stuck with no ride and running out of groceries .... Any help / ideas or suggestions would be GREATLY APPRECIATED....
THANKS
BMAC49
Old Dec 21, 2019 | 08:18 PM
joey2fords's Avatar
joey2fords
what engine ?
Old Dec 21, 2019 | 08:42 PM
torq'ta 5 8's Avatar
torq'ta 5 8
check for codes
Old Dec 22, 2019 | 10:52 PM
Bmac49's Avatar
Bmac49
Originally Posted by joey2fords
what engine ?
351w stock with 287k miles on it
Old Dec 23, 2019 | 07:31 AM
rla2005's Avatar
rla2005
Does the Check Engine Light (CEL) illuminate when you cycle the key from Off to Run?
If it does come on, does it turn off when cranking the engine?
bergy 2000
Modular V10 (6.8l)
13
May 16, 2023 02:49 PM
Abomb
1983 - 2012 Ranger & B-Series
Dec 17, 2015 12:44 PM
Midnightride42
May 9, 2009 11:56 AM
