P0470 and no boost
Old Dec 13, 2019 | 08:15 AM
snowdog79's Avatar
snowdog79
Question P0470 and no boost
So my ‘06 is showing P0470 Exhaust Pressure Sensor code, and is not making any boost. We just pulled the turbo apart to clean the vanes, reassembled everything and now this. I have read about cleaning the sensor, checking the wiring to it, etc., but I have not read about the no boost issue accompanying it. So really my question is, am I chasing just one problem, the pressure sensor code, or could I be chasing two (or more) separate issues (sensor and another causing the no boost)? Thanks in advance or any insights.
Old Dec 13, 2019 | 09:23 AM
bismic's Avatar
bismic
Verify MAP, EBP, and Baro are all reading the same at KOEO.
Inspect the EBP sensor connector and wiring.
Most (not all) of the time a P0470 is solved by a new EBP sensor.
Old Dec 13, 2019 | 11:43 AM
SmackDaddy's Avatar
SmackDaddy
Pull the EBP tube completely off exhaust manifold and thermostat and clean her out really well as well as the sensor. The turbo needs this value to operate correctly.
53jimc
Nov 19, 2018 06:53 AM
Greg W.
Dec 29, 2012 01:27 PM
teague350
Sep 30, 2011 04:49 PM
baredog26
Dec 9, 2010 11:30 AM
bobrc
Aug 24, 2008 12:56 PM
