Boost Issues
Old Nov 17, 2018 | 11:51 AM
53jimc's Avatar
53jimc
Boost Issues
Hi All. I haven't posted in a while, truck has been doing good recently.
Now, boost issues are cropping up.
I had noticed that randomly, boost would just disappear, then come back by itself. Running a stock tune.
I put EBP, MAP, BARO, BOOST and VGT on my edge CTS to see what was happening.
EBP looks normal and responds with the throttle as you would expect.
BARO is consistent, 14.3 in my area.
VGT responds normally, as long as I have MAP
MAP is the one that, at first, appeared to be the issue. It would read normally, then go to atmospheric and not budge. When that happens, VGT goes to 15% and won't budge.
I put a new MAP sensor on it, cleaned out the orifice on the intake manifold, confirmed the hose was clear and electrical connection was solid, then BOOST got worse. Now it rarely boosts as it should.
One other symptom to think about, not sure it's related:
When the truck is cold, 80-90 ECT, on acceleration MAP will go to around 30, BOOST to around 22, but absolutely no power. How could I possibly have that much boost but the truck feels like it is bogging down, about to stop running? I also get big time turbo fart when I let off the accelerator under those conditions.
I do have P0470 most of the time, even though the EBP value does display on the scanner.
When no boost appears I get P0069 MAP Baro correlation.
I also get P0299 underboost when the MAP doesn't read and the VGT goes to 15%.
Possible causes?:
Wiring/harness issues?
Bad new MAP sensor?
Turbo bad? (not spinning?)
VGT actuator issues?
Cat stopped up?
Anyway, any insight is appreciated. I am going to start digging into it now. The way my job is I don't have much time during the week to actually work on anything. Work, eat, sleep, repeat.
Old Nov 17, 2018 | 01:51 PM
xcrsp440's Avatar
xcrsp440
I think the ebp is causing issues.
Try unplugging it and see if anything changes.
Remove the sensor, clean it thoroughly, clean the tubing going into the manifold.
Old Nov 19, 2018 | 06:53 AM
53jimc's Avatar
53jimc
Thanks xcrsp440, I appreciate your input.
I cleaned the EBP sensor, sensor mount, tube and maniifold fitting.
The tube and fitting seemed ok, they were clear.
There was some buildup in the 45 deg mount and I think it was stopping the sensor from reading correctly.
All is good and it is boosting normally now.
Jim
Shaun Fed
6.4L Power Stroke Diesel
Jul 25, 2019 05:12 PM
Knucks
Apr 3, 2017 01:35 PM
lsramek1
Nov 28, 2011 08:47 PM
bobrc
Aug 24, 2008 12:56 PM
Geoff Brown
21
Apr 27, 2006 12:25 AM
