Old Dec 12, 2019 | 08:16 PM
glincecum's Avatar
glincecum
2010 4.6 3V dying at slow speeds, erratic idle intermittently. Anyone experienced this?
Old Dec 12, 2019 | 08:25 PM
steve(ill)'s Avatar
steve(ill)
If the MAF is dirty or faulty ( Mass Air Flow Sensor), then you can have those problems.
Old Dec 12, 2019 | 08:58 PM
glincecum's Avatar
glincecum
Thanks, will look into that, also forgot to state that afterwards, it will spin over excessively before it will start back up. It's my nephew's truck. I used to be a senior master tech until 2007, then I went to work in the Gulf of Mexico, better money less stress, no customer b.s.
Old Dec 13, 2019 | 09:18 AM
steve(ill)'s Avatar
steve(ill)
excessive cranking could be loss of fuel pressure in the fuel rail when setting overnight...... Possibly leaking off... possibly weak fuel pump... possibly the FPM ( pressure module) is having some trouble... you have a pressure module ?( not sure).
Old Dec 13, 2019 | 09:19 AM
steve(ill)'s Avatar
steve(ill)
And if the MAF is defective and giving poor air inlet flow numbers............. that might be the extended cranking problem.
Old Dec 13, 2019 | 09:21 AM
explorerdriver's Avatar
explorerdriver
MAF usually causes dying on pedal tip in. Also high identical LTFTs when you scan it. Can't hurt to clean it, there is a spray for $6 or so.
Also Throw a fuel pressure gauge on it, see what the numbers are.
Dalief Tacking
Feb 5, 2025 08:13 PM
Jkhuge
2004 - 2008 F150
Sep 28, 2017 03:12 PM
2007sporttrac
May 1, 2015 06:36 AM
sdbiddle
Jul 18, 2009 08:36 AM
adams.construction
19
Feb 25, 2009 11:54 AM
