05 f150 throwing P0191 code
Old Apr 5, 2015 | 12:50 PM
Jkhuge's Avatar
Jkhuge
Can anyone tell me where the fuel pressure regulator is located, I've located every othe part related to the fuel system accept the regulator, please help!
Old Apr 5, 2015 | 10:39 PM
wbrook_ford's Avatar
wbrook_ford
What engine?
I know for a fact that 5.4s don't have an actual fuel pressure regulator, more of a rail pressure sensor. With returnless fuel system, they use the fuel pump duty cycle to maintain rail pressure.
Old Apr 6, 2015 | 02:11 PM
Jkhuge's Avatar
Jkhuge
Thanx wbrook, I appreciate the help I ended up buying the repair manual and came to the same general conclusion. I replaced the fuel pressure sensor and the fuel pump driver module, and she fired right up, actually fired right up after the sensor was replaced, but I checked the module and it wouldn't have been much longer for that to fail (corroded to all hell)!
Old Apr 9, 2015 | 05:54 AM
red car's Avatar
red car
Hi Jkhuge,
I look up possible causes of P0191:
DTC Definition:
P0191 - Fuel Rail Pressure Sensor Circuit Range/Performance
Possible Causes:
- High fuel pressure
- Low fuel pressure
- Damaged FRP sensor
- Excessive resistance in the circuit
- Low or no fuel
- Wiring harness connector of the fuel pressure sensor
- Vacuum leaks
- Fuel
Old Sep 28, 2017 | 03:12 PM
tdubb843's Avatar
tdubb843
I'm having issues with this P0191 code on my 2005 ford f150 lariat 5.4
Dealership changed throttle body, and it did nothing. New fuel pressure sensor didn't fix either. The FPDM is in good shape.
Ford has had the truck for 2 weeks now and still have no answers. Nothing but the 700$ they charged me for the throtttle body replacement, that did nothing.
Dalief Tacking
Feb 5, 2025 08:13 PM
cvCNG
Alternative Fuels, Hybrids & Mileage
May 18, 2021 11:50 AM
horracecox
Apr 5, 2018 01:07 PM
Boss_358
General Automotive Discussion
Dec 30, 2010 07:14 PM
