Are 73-79 round headlight buckets the same as 78-79
I have a 78 f150 and my round headlight buckets got rust in them. was looking to get some new ones. but the only round ones they list are for 73-77. and square for 78 and 79. are the round bckets on the earlyer trucks the same as mine then or they not reproduced.
They might be salvageable with a bucket of Evapo Rust. Stuff does wonders.
I soaked them for about 2 days each. I got new adjusting screws for a couple of bucks.
I didn't take any pictures after repainting, but they turned out great.
I got a 3 gallon bucket and it has paid for itself several times over.
Just a thought.
Before
Before
After soak. Before Paint
After soak.
After soak.
Just a thought.
Before
Before
After soak.
After soak.
Standard headlight for '78 was still round, even with the new grille and core support. If you opted for a Ranger XLT I think it was, you got the rectangular headlights. Then in '79 all trucks had them.
So I can see the '78 buckets being slightly different like was said. Not sure if that means that a new pair of '73 to '77 buckets couldn't be made to fit, but it might take more tweaking than it's worth.
I'm a big fan of Evap-o-Rust too. Have a 5gal bucket of it in the garage that I should start on soon now that I've used up the 1gal jugs.
Good luck with yours gogeta. Maybe the rust isn't so bad? Either way, maybe someone has a side-by-side view of the two styles of bucket as well.
Paul
Paul
Just a thought.
Before
Before
After soak.
After soak.
Just a thought.
Before
Before
After soak.
After soak.
I didn't replace the little spring and I don't know how difficult they are to find, so don't lose them.
Also, I got some replacement adjusting screws from a local parts house, and the heads on the screws were too small and slipped through the notches. So if you go that route, take one with you to check.
I ended up getting them from Rock Auto and a much better price and they fit much better.
Drewski 2
07-28-2017 07:30 PM
