LED Headlight Cracking
Old Oct 11, 2019 | 11:02 PM
Gasgzlr's Avatar
Gasgzlr
I did some looking online and on the forum, but couldn't find much. Has anyone seen this issue come up? I didn't hit anything and they seem to be getting continually worse. It's a pretty expensive option to have them looking like this after 2 years!
Old Oct 11, 2019 | 11:10 PM
Barbero's Avatar
Barbero
If you do replace the outer plastic lens, I suggest then covering them with 3M clear film. I did mine when new and the lights still look brand new after 2 years...
Old Oct 11, 2019 | 11:17 PM
Gasgzlr's Avatar
Gasgzlr
I really wish I had XPEL on them like I have on the painted surfaces, you're right. Can you buy just the outer lense for these?
Old Oct 11, 2019 | 11:42 PM
2013xlt's Avatar
2013xlt
Are you past the bumper to bumper warranty? If not, Ford might warranty it. There's been quite a few cases of this problem here.
Old Oct 11, 2019 | 11:45 PM
Gasgzlr's Avatar
Gasgzlr
Unfortunately, I'm well beyond the 36k mark. My sister's other half is a Ford parts person, so he's looking into options. I wish they sold a new lens, I really like how well these work otherwise!
Old Oct 12, 2019 | 12:01 AM
2013xlt's Avatar
2013xlt
It's really hard to tell how deep those cracks are from all the photos I've seen. Are they quite deep? It looks like it is just a failure of the clear coat applied over the plastic lens. If that's the case it could be wet sanded carefully to the plastic lens, re clear coated with a good quality 2K (2 component) clear coat and 3m ppf (from amazon or xpel from a professional) over top of it.
I could be totally wrong on this though but it looks exactly like what happens to 2k clear coat when prep wasn't done correctly or 2k was sprayed over a 1k paint. The failure of the 2k clear coat usually takes a year or two before cracking and then it starts peeling/flaking off sometime afterwards.
Old Oct 12, 2019 | 08:58 AM
Gasgzlr's Avatar
Gasgzlr
It appears this goes all the way through the plastic. I did manage to find another post last night with a couple of pictures that were just like mine. It starts in the inside corners of the "c" shape and spreads from there. Almost looks like stress cracks.
Old Oct 12, 2019 | 10:27 AM
2019er's Avatar
2019er
No problem so far since purchase last Halloween. I have them in auto mode, so they're always on when the truck is. 18k miles.
Old Oct 12, 2019 | 12:03 PM
HRTKD's Avatar
HRTKD
No cracks on my '17 LED lens. The lights in auto mode all the time and I have 3M Clear Bra covering them.
Old Oct 14, 2019 | 08:46 PM
dzlbudman's Avatar
dzlbudman
My 2017 did the exact same thing. You’re looking at roughly 1k per side to replace. Mine occurred around the 60K mile mark. No impact or damage before the cracking started.
Old Oct 15, 2019 | 08:10 AM
D3thM3tal's Avatar
D3thM3tal
Both sides look like that? I've got a pass side 19' headlight with ~6k miles on it with busted tabs on it. Shoot me a PM.
Old Oct 15, 2019 | 02:21 PM
honda250xtitan's Avatar
honda250xtitan
if anyone finds a source for JUST the lens PLEASE post it in here. One of my halogen lens also has stress cracks (from my own doing when i took it apart for the retrofit) they aren't nearly as bad as those but it'd be nice to replace. you can get a pair of halogen assemblies from 1aauto for 370$. Could cook them in the oven and separate them and put them on your LED headlight.
I would ASSUME the lenses are exactly the same between LED and Halogen.
https://www.1aauto.com/2017-ford-hal...QaAvnSEALw_wcB
Old Oct 15, 2019 | 05:23 PM
tomfordgt's Avatar
tomfordgt
I've got a set of stock halogen housings that I just took off of a 19' F-450. They have 40 miles on them.
mwgus
Nov 3, 2021 05:10 PM
bart f-350
Australia Chapter
23
Mar 24, 2018 02:01 AM
kbarbee95
27
Mar 30, 2016 06:00 PM
HokieHiVPI
May 26, 2014 06:39 PM
whitebus61
Nov 3, 2009 10:53 PM
