window regulator
Old Dec 1, 2019 | 10:07 AM
beartracks's Avatar
beartracks
window regulator
Might have to replace this roller in my Electric-life electric window conversion. Window drags badly going up. Any one no the best way to remove/reinstall it? Has to be swedged in some way.
Old Dec 1, 2019 | 02:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Is this the original window roller or the roller used with the conversion?
Old Dec 2, 2019 | 09:43 AM
beartracks's Avatar
beartracks
It'a an original from D. Carpenter. I'm assuming it sill fit the same as the electirc kit. If I had it out it would be easier as I could probably rig up something with a flaring tool.
Old Dec 2, 2019 | 10:45 AM
DB429SCJ's Avatar
DB429SCJ
Maybe one of these would work;https://www.dormanproducts.com/gsear...+Replacement.I
Old Dec 2, 2019 | 03:38 PM
broktruk's Avatar
broktruk
Lightbulb
Looks like it should work. Simplest way would be to get a bolt in one instead of trying to mushroom the replacement.
Old Dec 3, 2019 | 09:40 AM
5851a's Avatar
5851a
Get the bolt on one and save a ton on band aids.
Old Dec 3, 2019 | 12:44 PM
beartracks's Avatar
beartracks
Where to find a bolt on one?
Old Dec 3, 2019 | 04:09 PM
5851a's Avatar
5851a
I have bought them from Ford years back. Help section in auto parts. Might try NAPA. Or type in that Dorman number the OP posted.
Old Dec 3, 2019 | 05:29 PM
broktruk's Avatar
broktruk
Originally Posted by DB429SCJ
Repost: gonna have to look. Hopefully you dont have to mix/match to get what you need
dobenator
Sep 3, 2019 12:57 PM
BTclassics
Aug 4, 2019 05:30 AM
chill59
Jun 22, 2019 02:42 PM
bstephen33
'80-'86 FAQs (Frequently Asked Questions)
Apr 5, 2019 01:12 PM
bstephen33
Jan 20, 2011 12:07 PM
