Nylon Window Rollers Don't Roll
Old May 4, 2017 | 11:13 PM
BTclassics's Avatar
BTclassics
I installed new nylon window rollers in the extended window lifts (for solid side window conversion) on my '54 F100. They fit so tight that the rollers don't roll. I'm afraid that when I install the window, it's not going to slide back and forth. Are there any tricks to getting these to operate properly?
Or did I install the rollers correctly?
I assembled them in the channels first and then slid them on to the window regulator posts. Compressing the spring in order to get the horseshoe clip in was quite difficult.
Window rollers I used:
Thanks!
Old May 5, 2017 | 06:28 AM
544tess's Avatar
544tess
The ones I installed were tight also.
I greased the track slots and just used it.
Works a lot better than one roller intact and and one in the bottom of the door!
Old May 5, 2017 | 06:37 AM
BlueOvalRage's Avatar
BlueOvalRage
Just an observation as I have no experience with that sort of kit, but the rollers will never "roll" with that arrangement. The tight contact with the upper and lower bar at the same time prevents it. At best, they will slide. Perhaps that's the intent? Modern riser assemblies use square or rectangular nylon sliders in those positions.
Old May 5, 2017 | 08:19 AM
abe's Avatar
abe
I think you are OK. Even with my old "rollers" they don't roll, they slide. I used white lithium grease and my windows with all old equipment go up and down easily.
Old May 5, 2017 | 05:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks!
This is a replacement (repro) window roller. AFAIK: The originals were all metal.
BA-7023240-A .. Window Roller / Reproduced.
1952/58 Ford Passenger Cars; 1953/56 Trucks; 1955/60 Thunderbird.
GREEN SALES CO. in Cincinnati OH has 10 = 800-487-9653.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3,750 = 800-476-9653.
Both of the above may be repro's, but I doubt the following is:
SOEBY MOTOR CO. in Walhalla ND has 1 = 701-549-3711.
Old May 5, 2017 | 08:26 PM
BTclassics's Avatar
BTclassics
Interesting stuff!
The metal ones rolled so I was concerned about these nylons ones.
I measured the window lift opening where the rollers are. The new extended ones were 1/8" narrower (tighter) than the originals.
If this is normal, I'll go ahead and install the window.
Old Aug 1, 2019 | 10:58 AM
clark grizwald's Avatar
clark grizwald
I am trying to install the rollers and am wondering if someone can show me where the spring and plate are supposed to be relative to the channel metal..
Old Aug 1, 2019 | 07:04 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Griz,
The spring and plate on one side of channel and the nylon head on the opposite side of channel.
Old Aug 2, 2019 | 03:03 PM
clark grizwald
Makes sense, Thanks!
Old Aug 3, 2019 | 04:24 PM
Jafo56's Avatar
Jafo56
Just fought with these yesterday!......... final analysis..............JUNK!...... there tight and don't role!....
Old Aug 3, 2019 | 09:23 PM
abe's Avatar
abe
They slide, lube them up.
Old Aug 4, 2019 | 05:30 AM
Indybeer's Avatar
Indybeer
Mine were also tight, but a generous coating of white lithium grease to the rail and "rollers" and all is well.
bstephen33
'80-'86 FAQs (Frequently Asked Questions)
Apr 5, 2019 01:12 PM
rc1099
Oct 19, 2012 01:41 AM
bstephen33
Jan 20, 2011 12:07 PM
Ford Fx4
2004 - 2008 F150
Mar 5, 2007 11:33 PM
imlowr2
Jun 26, 2006 10:12 PM
