'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
FAQ - 1985 f150 wing vent window - How to remove the glass
Old 01-19-2011, 04:16 PM
bstephen33's Avatar
bstephen33
bstephen33 is offline
bstephen33 is starting off with a positive reputation.
I am new to FTE but have previuosly found many answers here. I need to remove the wing glass to straighten the frame. Somehow it was bent and the glass will not seat properly.
Thanks in advance!!!
Barry
Old 01-19-2011, 05:38 PM
dohc_chump's Avatar
dohc_chump
dohc_chump is offline
This space for rent...
dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.
Pretty simple.
If you have manual windows, remove the crank.
Remove the screw in the arm rest cup
Pull off the door panel.
Remove the two screws holding the vent window.
Remove this bolt. You'll then want to move the main window out of the channel. Pull back your weather stripping and go to work trying to pull the vent window out. You can also try opening the vent window and hitting the frame with the flat of your hand. They don't usually come out that easily, so don't give up. Good luck.
Old 01-19-2011, 07:33 PM
GotFord83
GotFord83 is offline
GotFord83 is starting off with a positive reputation.
Nice write up....hope I can add to it....what is involved for just removing the main window?
Old 01-19-2011, 11:07 PM
dohc_chump's Avatar
dohc_chump
Remove the bolt for the back window channel.
Here you can see the back window channel.
Roll the window up in the door. Reach in and move the channel down and towards you.
Roll the window back down and make sure it is no longer riding in the channel. Pull the window to the back to pop it out of the front channel.
Open the vent window as shown and start rolling the window up. There is a single square roller that the window track rides on. You'll need to tilt the window out and up as shown in the pic to slide the track off.
Here is a pic of the roller and the window track.
Install is the reverse of removal. It takes a little maneuvering to get the roller back in the window track.
After you get the roller back in the track roll the window all the way down making sure it's not in either window channel. Also make sure you have the back channel pulled towards you.
Place the window back into the front window channel.
Roll the window up again and line up the rear channel.
Put the bolt in finger tight and test to make sure the window is in properly.
If all is ok, tighten up the bolt and recheck that the window rolls up and down easily.
Hope that helps.
Old 01-20-2011, 05:08 AM
GotFord83
Yes it does thanks a lot !!
Old 01-20-2011, 08:25 AM
1986F150six
1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
dohc_chump,
Just added positively to your reputation. Your input went beyond the normal input. Thanks!
Old 01-20-2011, 08:58 AM
bstephen33's Avatar
bstephen33
dohc_chump,
Thank you very much for the response. WOW!!! The pics are great, it all makes sense now.
I will give it a try tonight. Thanks again!!
Old 01-20-2011, 10:49 AM
Derrick lane
Derrick lane is offline
Derrick lane is starting off with a positive reputation.
A friend of mine had a driver side wing window assembly.
I needed the passenger side for my truck he sold it to me for 15.00.
It might be a problem getting the glass out and back in if the rubber
seal is old and brittle.
If it's the driver side i'll see if i can get it if you want.
Old 01-20-2011, 12:07 PM
dohc_chump's Avatar
dohc_chump
Glad I could help! Thanks for the reps guys
Old 04-05-2019, 01:12 PM
Camshaft's Avatar
Camshaft
Camshaft is offline
Camshaft is starting off with a positive reputation.
Thanks for this post I am going to be doing exactly that when the weather gets a little dryer and warmer I have new vent window rubbers and window felts and all new door trim to go in along with new carpet this spring.
dadsgp
17
07-25-2018 06:56 PM
77megacab
32
12-03-2017 01:44 PM
F&M
11-01-2016 05:14 PM
traxx808
22
02-21-2016 06:12 PM
kotadawg
10-22-2015 09:46 PM
Quick Reply: FAQ - 1985 f150 wing vent window - How to remove the glass
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
