Get a junkyard OBS 460 truck oil pan. '92-'96 f250 or 350 with a 460. Take the pickup tube also and you will need a new oil pump. Mou ting for the pickup is different.
The only difference I can think of in pans is the 2 bolt's that go into the timing cover are different sizes from early to late.
Correct...on the corner bolts of the pan you have to open up the reinforced hole in the pan gasket. If I recall correctly I used a step drill and held the gasket against a piece of cardboard with a block of wood under it for support. I went in about half way and then flipped the gasket over and came from the other side. You have to hold the pan gasket tight so it doesn’t grab and spin on you. Take your time and it will all turn out with no issues.
