Sponsored by: Real Truck
2007 5r110 issues
Old Nov 25, 2019 | 05:50 PM
pfoley12's Avatar
pfoley12
2007 5r110 issues
New member in hope to solve my trans issues. 07 6.0 185k miles. Had a reputable shop rebuild my 5r with a rev max kit and all new solenoids and temp sensor. Its commanding 3rd/5th at a stop intermittently, when you give it slight throttle it will jump back to first and shift as it should. When you give it heavy throttle it'll sometimes shift 1-2-3-4 seems to slip 3-5 and commands 4th. It threw a temp sensor code last week, replaced it and problem came right back. Rather not throw parts at it but almost convinced it's a tcm/harness issue. Other than that it hasn’t thrown any other codes. It’s been in and out of the shop the past 5 months and need this truck squared away asap. Any help is appreciated thanks.
Old Nov 26, 2019 | 06:04 PM
pfoley12's Avatar
pfoley12
Bump! Any tranny experts
Old Nov 26, 2019 | 07:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored?
Old Nov 26, 2019 | 07:48 PM
pfoley12's Avatar
pfoley12
None at the moment. Other than a p0700 last week before replacing temp sensor, no codes since
Old Nov 26, 2019 | 09:00 PM
Mark Kovalsky
P0700 means the PCM knows SOMETHING is wrong with the trans, but hasn't been able to pin it down. So that code only confirms that something is wrong.
This is going to be very hard to fix without codes. Watching live data from each sensor may pin down where the problem lies.
Old Nov 26, 2019 | 09:39 PM
pfoley12's Avatar
pfoley12
I should've clarified that it sent a p0700 before it threw the temp sensor fault code. We've put two new oem sensors in it now. I did one earlier this summer before the trans went out. Then the shop got it to throw the same code.
Which sensors should I be monitoring? Possible from the torque pro app or only from IDS?
Old Nov 27, 2019 | 05:58 PM
Mark Kovalsky
I use Forscan to monitor. EIther IDS or Torque Pro should work, too.
Look at pedal position, vehicle speed, engine speed, TRS input, trans turbine speed, trans intermediate speed, trans output speed, gr_cm (commanded gear,) and trans temp. I'm sure there are more, but that's what I thought of right now.
Old Dec 4, 2019 | 04:28 PM
pfoley12's Avatar
pfoley12
Update not fixed and no codes still. But it only happens when the truck is shut off for a couple minutes every time I run into the store. Seems like a pressure issue to me. A wiring issue would be more consistent I'd think. After the truck is at operating temp it shifts just about perfect in stop and go traffic. Otherwise it's super slow to downshift when coming to a stop, sometimes 2-3 seconds other times forever until you give it throttle. Also torque only provides me commanded gear, and trans temp.
Old Dec 26, 2019 | 01:08 AM
pfoley12's Avatar
pfoley12
Mark, finally got a p2703 code today. I'm thinking it's a harness issue, recently I've been having coolant spitting from the reservoir leaking right down into the connector for the trans harness. Will report back when I get a chance to repair/replace. Does this seem pretty likely the cause of my issue? It is studded so shouldn't be head gaskets but that's another topic
Old Dec 26, 2019 | 08:40 AM
Mark Kovalsky
It could be a harness problem.
Tomek6
2009 - 2014 F150
Feb 9, 2018 07:12 PM
diesldoct
1997 - 2003 F150
Jan 12, 2017 08:37 PM
daddogg
Jan 18, 2015 01:06 AM
94GreenTruck
45
Mar 24, 2014 10:26 AM
Chad Winship
1978 - 1996 Big Bronco
Jul 12, 2008 07:41 AM
