Sponsored by: Real Truck
Headlight bolts
Old Dec 25, 2019 | 01:13 PM
frysl's Avatar
frysl
Angry Headlight bolts
Merry Christmas all.
im having to remove my headlights in order to replace a bulb on my 2015 F-250. The 10mm bolt on the bottom of the assembly is a problem. I can see it, but can’t get a socket to it. The bumper is too high. Is it possible I’ll have to remove or lower the bumper to get to the bottom bolt? It’s the same way on both sides.
steve
Old Dec 25, 2019 | 09:21 PM
Colorado350's Avatar
Colorado350
On my 7.3L the frame mounts are slotted to allow you to adjust the height of the bumper. You may be able to loosen the bumper bolts and the bumper will simply drop a bit.
Old Dec 25, 2019 | 09:32 PM
frysl's Avatar
frysl
Thanks, as it is now, I can only see the top half of that bottom bolt. There’s not enough room to get the socket in to the bolt.
Old Dec 25, 2019 | 10:15 PM
254XP3's Avatar
254XP3
Sounds like your bumper has been either removed/replaced at some point and it was adjusted to a level appearance and not level and allowing access to the headlight lower bolt. If you simply loosen the bumper bolts/tow hook, it will drop down almost 2 inches. You can then reset the height/level and still allow easy access to the lower headlight mounting bolt. Having 2 people to hold and adjust makes it much easier but can be done by yourself.
Old Dec 26, 2019 | 08:48 AM
frysl's Avatar
frysl
Smile
Thanks! I appreciate it.
Dakrri
Mar 27, 2010 04:46 PM
proudtruck
Mar 17, 2010 11:19 PM
jdizz890
Jun 17, 2009 06:39 PM
06F250KR
Jun 24, 2007 09:47 PM
oldbluetruck
Mar 6, 2005 07:12 PM
