P0135 and p0030 Code help
Old Feb 9, 2018 | 06:00 PM
Tomek6's Avatar
Tomek6
Hello
Ive got a problem with my 2012 Raptor. I’ve gotten the o2 sensor codes. We replaced the bank 1 sensor 1 twice in case we got a defective sensor. We checked the voltage in the wiring harness and everything checks out so we eliminated a burnt wire or short. The fuel tables haven’t changed so I don’t think it’s a vacuum leak. I cleaned the MAF sensor. The exhaust does not have any leaks. Also when we reset the memory and do a self test with the diagnostic tool. It passes diagnostics. No codes. I drive the truck home. No codes. I noticed when I do a cold start and watch the dash. The engine light comes on as water temps reach operating temp. I know the o2 sensor heater is supposed to be at its operating temp based on coolant temp so that makes sense. What I don’t get is what is causing it? Everything seems to be fine. The truck drives fine. Is there a Software update that I need or something I am missing?
Thank you
Old Feb 9, 2018 | 07:07 PM
pdqford's Avatar
pdqford
I’m sure everyone would like to know the actual code that comes up.
Old Feb 9, 2018 | 07:12 PM
Tomek6's Avatar
Tomek6
Sorry I put them in the title not sure if it’s showing up. It’s my first time posting. The codes are P0135 and P0030
alreadydeadford
31
May 9, 2021 07:21 PM
Suhaj213
1997 - 2003 F150
Jun 7, 2013 11:52 PM
bigwillie
13
Jul 3, 2006 12:28 PM
Caplax40
1983 - 2012 Ranger & B-Series
13
Mar 4, 2005 07:58 PM
shultzy501
1997 - 2003 F150
Feb 11, 2005 10:20 PM
