Lets talk lifters!
Old Nov 17, 2019 | 03:17 PM
  #46
SmackDaddy's Avatar
SmackDaddy
https://www.henkel-adhesives.com/us/...ctite_620.html
Old Nov 17, 2019 | 05:29 PM
  #47
ToolmakerRob's Avatar
ToolmakerRob
Welding precision components has always scared the daylights out of me due to the fact that as soon as you place a puddle of weld on a piece of steel two things happen:
1. Expansion at that point
2. The structure of that steel changes.
As it cools the weld now starts to shrink, things move and more than likely the camshaft is a different steel/hardness than the gear is. More often than not there will be tiny cracks in the weld. You can almost guarantee that any alignment/concentricity will change/most likely be worse.
Much better off to utilize a retaining compound. It would be even better if a small band could be machined/ground into the gear such as .250 wide and .003 deep to give the retaining compound a spot to hold.
Rob
Old Nov 17, 2019 | 06:08 PM
  #48
TooManyToys.'s Avatar
TooManyToys.
I was trying not to get wordy, but Rob has this covered.
If you look as the ID of the gear it’s been induction hardened. You can weld hardened metal, but you’ve lost all control over the metal crystals. It’s never somewhere I can to go in a shop environment.
This is the brochure on their retaining compounds.
http://dm.henkel-dam.com/is/content/...DesignGuidepdf
Hey Rob.
zerfetzen
May 19, 2012 08:11 AM
HonestEngine302
Apr 24, 2011 03:20 PM
f100_4me
Aug 15, 2008 12:14 PM
freemanrebel
Oct 26, 2004 06:26 PM
jmackie
Jul 14, 2003 07:30 PM
