Loose Valves and Pushrods
I had been hearing a ticking noise in passenger side valve cover, so I removed the cover to access damage. Upon removal I found the rear rocker arm very loose and all of the pushrods were loose through out all 8 valves and since they are self adjusting the cant be tightened anymore. With this being said its using alot of fuel consumption but the oil level never goes down. I figure that the heads are worn being that they are original and need to be replaced. I have an 289 cam just step above stock that I have handy to install when replacing the heads. Would that be ok as long as I replace the lifters and pushrods to match up?
I tried to adjust and upon as uncle a seasoned mechanic said you just do that valve lash turning engine to firing order and adjust, but they cant be adjusted anymore seeing they build up by themselves after tightening them. I think the heads are just worn out and need to replaced cause only one rocker are will move freely. Also it has serious marks cut into the under side of the rocker arm when removed to inspect it. So I assumed as weak lifters and pushrods due to cam wear. Note this truck has plenty of power use it for towing materials, just dont wanna cause anymore damage. I am going to have the heads redone by machine shop and install myself and with new cam also. I think you would call it an overhaul, I dont see any use in removing more cause like said it doesnt smoke or use alot of oil usually 1/2 quart every 6 months which I dont think is bad for 1979 engine. Was taken care of really well, anyways I am just wondering if I replace cam I cant buy stock pushrods and expect them to work with it, also doesnt really come with any specs on it. I guess I will talk to the shop once heads are done to see what pushrod lengths go with the new cam n lift.
You are totally right the valves arent self adjusting but but if you go thru the valve lash and the pushrods are still able to be turned easily with fingers. What would that be a cause of I just think replacing heads would take care of all of that I hope. I see you have a 1979 302 also I think they are really dependable engines being this one is stock from factory and still kicking rocks.
It may not be using oil now but when you increase the compression with a valve job, most likely it will start using oil. It's going to blow by the worn piston rings. So ,no , you are not giving it an overhaul. I mean this in a helpful way and just telling you what can happen unless you are lucky. JIM
There may be sludge built up in the lifters keeping them from "pumping up" completely. Marvel mystery oil or Valve-medic will help that situation if that is the cause.
I checked the pushrods and when put all on my straight edge they are fine I just threw the heads back on with a gasket n drove on to work until can get them reworked by local shop with excellent reviews from work done in past for other motors. I just think the heads are shot, like I said its getting plenty of oil pressure just the exhaust smells of raw fuel. But glad you agree with me on lifters and rods, just ready to get Ole Blue back on the right mpg lol.
BaronVonAutomatc
28
04-02-2016 05:16 PM
Bergerson
18
10-23-2011 06:34 PM
