Needs a new spark generator
Old Nov 5, 2019 | 12:38 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by BillyBob69
Where does that wire route to? Or is it going thru a relay?
Anyone got the charging system wiring?
Thanks all!
There are wiring diagrams that may be helpful to you in the 7.3L PSD Tech Folder under "Electrical" at the link below.
https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Nov 5, 2019 | 01:19 PM
Colorado350's Avatar
Colorado350
Thanks for the links! I will be digging into them today.
Alright check fuse 29 (5amp) under dash.
Damn site won’t let me load a pic, gets to 50% then crashes.
Old Nov 5, 2019 | 01:37 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
We had a similar problem. Had to change out the 3 wire plug on the back. I think it is a 3 wire!
Old Nov 5, 2019 | 07:56 PM
BillyBob69's Avatar
BillyBob69
So you know when they say...Don’t drive angry. Well don’t work on your truck when you have had a rough day. So apparently, when I was going through all the connections and cleaning n such... I missed reconnecting the one that led from the alternator to the second lug on the solenoid on the fender.
The end had dropped down below the solenoid hiding from me when I cleaned all the connections.
Soooooooo. I got home today...scratched my head for a minute then decided to just get in there and do it. Traced the wire from the alternator across the motor, under the battery try up to the solenoid and as I grabbed the wire the end of it jumped out and waved at me like a sick game of hide and seek. Ugh....
Thanks for all the info everyone. even if it was an OOPS.... it still led me to tracking down my result of being distracted when I worked on my truck.
now batteries hold at 12.7 and the digital display I have in the power port shows 14.4 when running.
Old Nov 6, 2019 | 11:16 AM
brian42's Avatar
brian42
Veteran: Navy
Glad it was a free fix!
I've had my share of 'oops' moments. I'd rather overlook something than chase down another problem any day. Plus it's good info for someone in the future too.
Cruiseomatic
Aug 19, 2017 08:38 AM
blp59901
Escape & Escape Hybrid
Jul 29, 2016 07:41 AM
white Buffalo
20
Aug 30, 2014 12:11 AM
mechmagcn
15
Aug 31, 2012 12:33 AM
crazymut
26
Jun 28, 2011 04:47 PM
