42 Pin Connector
Old Nov 1, 2019 | 09:41 AM
jimjokjv's Avatar
jimjokjv
42 Pin Connector
I have been searching trying to find someone that sells this connector. Mine no longer bolts together and is being held in place by a wire tie. I saw that one place used to sell the complete replacement but no longer has them.
Yes, I did look through the Ford Connector Catalog in the Tech Folder but didn't see it labeled plain enough for me to identify it. My schematic says it is C138F and C138M but also 12A581 appears.
Any help would be appreciated.
Old Nov 1, 2019 | 10:23 AM
FordTruckNoob's Avatar
FordTruckNoob
C138F and C138M are just the identifiers for the female and male halves of the connector in the wiring diagrams. 12A581 refers to the part number for the wire harness. For example, the engine bay side of the wire harness has part number 1C3T-12A581-P260F.
If the original connector is no longer made, it might be a good opportunity to replace it with something more robust like this:
Old Nov 1, 2019 | 12:17 PM
woodnthings's Avatar
woodnthings
Ford used these on many models. Check out your local junkyards, they have plenty of them. You can easily depin and repin them with your wires. I have made a couple sets of test tools using this method. Most yards only charge $10 for the parts.
Old Nov 1, 2019 | 01:21 PM
jimjokjv's Avatar
jimjokjv
Do you know if these are year specific? Will 99-03 all work?
Old Nov 1, 2019 | 02:12 PM
Bonanza35's Avatar
Bonanza35
yes they should. Cut enough wire or how ever you do it and then just go wi9re per wire.
Old Nov 4, 2019 | 03:44 PM
woodnthings
Many years will work. I would stick with looking at the similar years, but trucks, cars and expeditions all used this connector. They may be in slightly different locations, but are common.
Old Nov 5, 2019 | 02:49 PM
Fat Diesel's Avatar
Fat Diesel
Exploders and Mercury Mountaineers had the same connector for a few years.
Old Nov 6, 2019 | 02:46 PM
jimjokjv's Avatar
jimjokjv
Thanks for the help.
I won't be getting to this project for a while. Got too many other things going on right now.
KevinPC13
Sep 12, 2015 01:42 AM
Steve Lawrence
Electrical Systems/Wiring
Oct 18, 2014 05:55 AM
jtexfisher
Apr 19, 2011 03:25 AM
cbfomoco
Feb 7, 2007 10:04 PM
