351W no start
Old Dec 1, 2019 | 01:18 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Originally Posted by Weberman3
It dies after I stop spraying the carb cleaner.
In addition to verifying fuel pressure get some noid lights and make sure the injectors are pulsing
Old Dec 1, 2019 | 01:51 PM
torq'ta 5 8's Avatar
torq'ta 5 8
you can test your injectors, if you have fuel pressure and firing(starts on carb cleaner) see if they are opening
Part 3 -Ford 4.9L, 5.0L, 5.8L Index of Articles
Old Dec 1, 2019 | 03:57 PM
jackietreehorn's Avatar
jackietreehorn
Possibly a massive vacuum leak, did you smoke test?
Old Dec 1, 2019 | 04:54 PM
Weberman3's Avatar
Weberman3
Didn't do a smoke test and will be away from the truck again for a couple weeks sadly, but after that I'll have more than just a break/weekend to work on it.
Old Dec 20, 2019 | 06:31 PM
Weberman3's Avatar
Weberman3
So I checked all of cylinders but #3 and #4 (the back two on the passenger side under the manifold). I got some noid lights and they all worked and I checked all of the ohms on the injectors and they are around 14.5. I had some that I did not clean prior to putting back in and they are around the same 14.5 ohms. I rechecked the timing and put it back into the factory spot, checked all the wires and still nothing. Like I said, don't know about the back two cylinders with the injector ohms or if they are getting signal, but I thought with the front two getting signal that the back two should be fine. I checked spark on the front two cylinders on each side and they have spark. Still haven't done a smoke test but at this point it seems that fuel, spark and air is present and I'm at a loss. I really figured it would be signals to the injectors, or the injectors themselves since it doesn't make an attempt to fire but as soon as you open the throttle body, spray something in, it hits immediately and burns that and dies, or keeps running if you keep spraying.
Old Dec 20, 2019 | 08:48 PM
torq'ta 5 8
So the fuel pressure gets to about 44 turning the key. But the stream coming out is very little. I'm assuming since these are EFI and a small electric carb pump puts out 50 GPH that the little stream is no where correct.
with the gauge hooked up and you turn the key to on, watch where pressure goes to, then turn key off and watch gauge and see if the pressure stays high or drops slowly or quickly(should drop slowly) or could have leak in injector/s, then with gauge hooked up and truck running what is gauge reading(should be 31-36 psi) while running, may have already been asked, but have you changed fuel filter on frame rail lately
Old Dec 20, 2019 | 09:05 PM
Weberman3's Avatar
Weberman3
I used air pressure on the fitting on the rail and there is plenty of fuel now coming out of the fitting.
Old Dec 21, 2019 | 10:11 AM
torq'ta 5 8
that dont tell you if the pump is maintaining the needed fuel pressure to keep truck running, and I wouldnt use 90psi of air pressure to check 30-40psi fuel pressure, not sure what harm could be done, to injectors, fuel pressure regulator diaphragm ruptured, fuel filter blowing out insides, now even bigger trash could get by and clog injectors
Old Dec 21, 2019 | 12:18 PM
Weberman3's Avatar
Weberman3
I didnt check fuel pressure last night, only checked to see how much fuel was coming out, but I did check it before hand and it went to mid 40s and then slowly went down after a bit. I cant really check it when running unless I spray carb cleaner in there to make it run and check it that way.
Old Dec 23, 2019 | 05:53 PM
Weberman3's Avatar
Weberman3
I went to the junkyard today and pulled some injectors and replaced them. Even though the circuit tested good, once I pulled the rail and left the injectors on they weren't spraying. I replaced them all and its up and running. Not sure what truly happened with them, but oh well
Stephanie Lalone
1978 - 1996 Big Bronco
Apr 12, 2017 01:35 PM
parker_shelton
May 6, 2016 07:44 PM
meetre
Feb 23, 2015 10:29 PM
bigedusa
23
Aug 31, 2012 09:46 PM
flt04lee
16
Oct 18, 2008 03:07 PM
