help with koeo codes
Old Aug 28, 2012 | 05:45 PM
bigedusa's Avatar
bigedusa
Unhappy help with koeo codes
ok i have a 93 f-150 with the 5.0 automatic with o/d.The truck runs fair..
idels ok sometimes it will die on me..going down the rd and you give it some gas it seems to flounde for a few seconds then takes off as if you gave it more gas.Tha cel flashes mostly when you take your foot off the gas like going around a corner..SOOO i hooked up my reader and oh boy..i get koeo codes 10,11,31,33 and 34. on the koer codes i get 13,16 and 25..the koeo codes 31 voltage of the PFE or EVP is below minimum voltage of 0.24 volts..34 is PFE or EVP circut is above limits of 0.67 volts and code 33 i can find no info on....were does this voltige come from??I think its from the EMS or computer.. or is the codes saying the the PFE or EVP is bad??
Old Aug 28, 2012 | 07:12 PM
subford's Avatar
subford
To start with the 11 says you have no KOEO codes.
The codes after that are CM codes.
31, 33 & the 34 code all belong to the EGR system.
You do not have a PEF you have a EVP sensor mounted on top of the EGR valve.
These codes happened in the last 80 starts of the engine and there have been some time frame between them.
These codes most of the time wind up being bad wiring. The 33 code from memory without looking it up means the EGR valve did not open. This code comes in most of the time with bad vacuum lines to the EGR valve or to the EVR solenoid.
Again without looking them up it seems like the KOER codes you got are all from a cold engine.
I bet if you unscrew the big EGR tube on the bottom of the EGR valve and drop a coin in it and just snug it back on the engine will run OK. Then you can take the coin back out and fix the EGR problem.
Old Aug 28, 2012 | 08:07 PM
bigedusa's Avatar
bigedusa
Thanks Subford..I will try that in the AM.I do have vacuum at the EGR. i checked that this afternoon.I also unhooked the vacuum line and hooked a hand vacuum pump with a vacuum guage to it while it was running pumped it up and it held vacuum but the motor didnt change at all..I would have thought it would have changed..
Old Aug 28, 2012 | 08:27 PM
subford's Avatar
subford
If you pump the vacuum to the EGR valve while at idle the engine should die most of the time. Or at least start running very bad.
Old Aug 28, 2012 | 08:43 PM
bigedusa's Avatar
bigedusa
I pumped it up to 12 on the vacuum guage.it held the vacuum...I didnt know how high would hurt it but the motor didnt run faster or slower...
Old Aug 28, 2012 | 08:51 PM
subford's Avatar
subford
The EGR valve may be stuck open. That is why I said to put a coin in it to block the exhaust flow to the intake.
If you have a smooth idle right now the EGR valve is more than likely closed and the coin will not make any difference.
Old Aug 28, 2012 | 09:15 PM
Truckin Bob's Avatar
Truckin Bob
Stuck closed /defective EGR valve.............
Bob
Old Aug 29, 2012 | 12:35 AM
woodstock4130's Avatar
woodstock4130
had same problem 2 weeks ago
had the same codes....tested the egr ,which was fine,traced it to the sensor on top of the egr,tested it and it was bad...replaced it no more codes for that...still had a run rich code(hego sensor rich fault) which turned out to be the fuel pressure regulator.Which i replaced.
Truck runs great now and mpg got way better.
Old Aug 29, 2012 | 12:14 PM
bigedusa's Avatar
bigedusa
Ok i put the coin in the egr pipe and no change..im going to the parts store to get a EVP sensor..Round three..
Old Aug 29, 2012 | 01:12 PM
Truckin Bob
Wrong part ............ you need to replace the EGR valve.
Bob
Old Aug 29, 2012 | 01:56 PM
BRay09's Avatar
BRay09
Or take it off, clean it. Make sure it opens and closes, then put it back on. If you blocked off the egr and nothing changed, my bets are your problems are else where.
Old Aug 29, 2012 | 02:07 PM
subford's Avatar
subford
If no change with the coin in then the EGR valve is closed. More than likely wiring or the EVP sensor.
Old Aug 29, 2012 | 06:46 PM
bigedusa's Avatar
bigedusa
Ok this afternoon i changed the EVP or EGR valve position sensor,same deal same codes..Tomorrow i guess i will do the EGR valve after work.. Till then THANKS ALL..
Old Aug 29, 2012 | 06:48 PM
BRay09's Avatar
BRay09
Clean it before you spend $80 on a new one. They usually get carboned up.
Old Aug 29, 2012 | 07:12 PM
Truckin Bob
Yes, most definately !!!
Bob
