i just got a 91 f-150 six cylinder.it was running real bad.installed new plugs,wires.cap and rotor.it idels great.it has a bad hesition while driving.if i push the gas pedal down and power thru it it does not break up.it only happens when just driving and feathering the pedal....heres whats new on it..new fuel pump.fuel filter,plugs,wires,cap,rotor...when i got the truck the fuel pump would stay running when i turned the key so this truck would not run..messed with the plug relays and harness conections for the fuel pump and then it would start and has been fine...just need to get the bad hesition out of it...talked to alot of people and nobody knows what it is..need help.thanks guys..cj
Have you tried to pull any error codes that may be stored? If not go to fordfuelinjection.com for instructions on how to. You might also want to check your fuel pressure and you might also check around the engine for any vacuum leaks and possibly take the EGR valve off and clean it. Good luck.
The egr could be opening prematurely,causing the hesitation.U could pull the vac line and plug it and see if better, or pull the egr and make a pop can gasket WITHOUT the two holes the gasses go thru and see if maybe its stuck open
Are you saying you got no codes at all or you got the 11 or 111 all clear codes? If you got no codes at all you have a processor problem, if you got an all clear you could have a bad TFI module or weak ignition coil.. among other things.
I don't know.I had a mechanic use the handheld scanner and he said its not showing any codes not even stored codes. But the check engine light came on when I had trouble with the fuel pump so it should show a stored code right??
Yeah that's a sign of a bad processor, and so is the fuel pump that won't shut off, is it still doing that? You should try pulling the codes yourself, ground the STI wire in the EEC test connector harness and turn the key to run and the check engine light should flash the codes. www.fordfuelinjection.com has pics of the EEC test harness and data on the codes.
Cool.what's a processor and how much $ are they...haha.. No the fuel pump stopped running and I have been driving it now. I hope it will not start that again.
Pulled the vacum line off the egr and pluged it.and the truck runs a lot better not much hesition.but the check engine light is on. So all I need is a new egr or something else ???
my egr is disconnected and the check engine light hasnt been on for years, its still there but the holes are welded shut and line is capped. A code does show when checkin but light is never on
I believe that if the electrical switch is disconected the light will come on, so to run w/no light and no egr you could remove the switch from the egr housing and let it float. My EGR was 3 seperate pieces electrical switch, valve body, and EGR exhaust tube.
