New stickers!
Old Oct 31, 2019 | 06:53 PM
kd5zll's Avatar
kd5zll
New stickers!
I just found stickers on my engine, i didnt know were there..... just got home and one a whim i used this stuff from sams club that we clean the oven with, because i thought, hey, my engine is hot, and that cleaner is supposed to be used at 200 degrees, or there abouts.... wow. So great
Old Oct 31, 2019 | 06:56 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I remember when I cleaned the caked on oil on the passenger head and found my International sticker. It was pretty cool and inspiring to clean more.
Old Oct 31, 2019 | 07:02 PM
kd5zll's Avatar
kd5zll
Thats the one! I didnt know it was there!
Old Oct 31, 2019 | 08:43 PM
Wes444's Avatar
Wes444
There's also barcodes n engine number stickers on the driver's side to discover
Old Oct 31, 2019 | 11:00 PM
kd5zll's Avatar
kd5zll
Those, i already knew about. Thats how i got my engine manufacture date. April, '98
Old Nov 1, 2019 | 05:37 AM
FordTruckNoob's Avatar
FordTruckNoob
My stickers got painted over by Swamps.
Old Nov 1, 2019 | 02:37 PM
Bonanza35's Avatar
Bonanza35
Leonard, now you need a T4 with the 366 SEX turbo. Impressive signature. PMS for sure. Like to have that signature myself.
Old Nov 1, 2019 | 05:35 PM
FordTruckNoob
Chet, I was saving up for a T4/SXE setup until this hapened: https://www.ford-trucks.com/forums/1...eleration.html
Old Nov 1, 2019 | 10:33 PM
Bonanza35's Avatar
Bonanza35
I remember that now. That sucked. At least you got that one fixed. Maybe next year.
Old Nov 2, 2019 | 10:21 PM
RA101725's Avatar
RA101725
Banned
I wish I could just snap my fingers and remove every trace of grime from my engine. That would be exciting. (Doing it the hard way would not be.)
Old Nov 2, 2019 | 10:24 PM
kd5zll's Avatar
kd5zll
Half of my point in sharing. I sprayed it on hot. Then i got my yard sprayer. With the hand pump and wand, filled it with hot tap water, and rinsed the cleaner off. 30% of the gunk gone, in 10 minutes, without busting my knuckles even once
Old Nov 3, 2019 | 09:20 AM
RA101725's Avatar
RA101725
Banned
I used to use that Gunk "foamy engine brite" product on previous vehicles with decent luck but I have been leery about doing that with this engine and have just learned to live with it even though I am a clean freak. (Outside of the truck gets washed all the time.) Is it not that big of a deal if water gets down the back through the hole into the bellhousing?
Old Nov 3, 2019 | 09:33 AM
kd5zll's Avatar
kd5zll
I am gonna leave that answer to better minds than mine. @Sous Perhaps would know. My personal thinking is that people mud and offroad these, soooo water really shouldnt be a huge concern. Ill sit back and see if im crazy or not... lol
Old Nov 3, 2019 | 03:20 PM
Sous's Avatar
Sous
FTE Emeritus
It IS a big deal for oil and oil water to get into the bell housing IF you have a ZF6 truck.This is a big deal because the clutch is almost certainly guaranteed to be contaminated.
I had a drainage pipe installed from the valley hole down to the bottom of the bell housing when I had my clutch replaced.
I use Simple Green and a low pressure sprayer (shower setting) on my garden hose. I make sure the engine is cold from sitting overnight. I make sure the front of the truck is slightly higher so the water can run out of the valley and off of flat surfaces. I also cover the alternator and power steering reservoir cap with plastic.
After letting the simple green soak for 10-15 minutes I rinse it off and immediately start the truck. I let it idle for 5-10 minutes then take it on a 10 mile drive.
This allows for any excess water to burn off. I did this several times to get to where it is now and it looks new.
Sometimes I use a bit of plastic polish on the hoses and large plastic surfaces., but it every time.
Old Nov 12, 2019 | 03:20 PM
MoBill122's Avatar
MoBill122
Papa Smurf
I followed Sous... I use Simple Green too. Engine bay doesn't stink afterwards either, like some products will do.
Used a pressure washer the first time.... blew off my stickers. Wish I knew where to get new ones !
Do cover up the alternator, etc.
Just think if you keep it clean, you can spot a new leak, before it becomes a major issue out on the road to nowhere.
Simps
Aug 25, 2017 11:52 AM
SpedKid94
20
Feb 9, 2016 07:33 AM
Tyler S
38
Feb 16, 2012 10:36 AM
rmalottwtes30
16
Aug 28, 2008 03:54 PM
79f-250custom
37
Apr 8, 2006 05:33 AM
