Cleaning an engine.
Old Jan 28, 2006 | 06:43 PM
79f-250custom's Avatar
79f-250custom
Cleaning an engine.
Hey guys.
what would you guys use to clean the oil and crudd off your engine? i would like to be able to eat off of my enging. but right now it has oil and dirt all over it. and i dont like that. any good tricks that would get that stuff off?
Thanks
Mitch
Old Jan 28, 2006 | 07:38 PM
Briansshop's Avatar
Briansshop
Spray "Gunk" works good for the greasy stuff. Do it w/ the motor alittle warm,let it soak in.When you've got alot of built up crud nothing beats the old elbow grease.Just gotta get in there & do some scraping & brushing. It will take a few rounds to get it really clean.
Brian
Old Jan 28, 2006 | 08:06 PM
Brians97F250Crew's Avatar
Brians97F250Crew
I'm with Brian above.
Gunk, warm engine and I'd use a pressure washer.
Old Jan 28, 2006 | 10:22 PM
fridgeddiesel's Avatar
fridgeddiesel
Anything in the engine compartment to avoid spraying with a pressure washer? Mine is in need of a cleaning when the weather warms up.
Old Jan 28, 2006 | 11:55 PM
79f-250custom
Thanks for the replys guys. ill go get sum gunk tommrow and start scrubbin.
thanks
Mitch
Old Jan 29, 2006 | 09:11 AM
DaBigTow's Avatar
DaBigTow
If you have a Tymar, Kwik, or 6637 filter, put it in a heavy-duty plastic bag & tie it off. Other than that, you might want to stay away from the fuse/relay box in front of the master cylinder. Wear a full-face safety shield because you're going to kick back a lot of junk at the car wash.
Old Jan 29, 2006 | 09:16 AM
1996pwrstrk's Avatar
1996pwrstrk
So everything else is pretty watertight ?
Old Jan 29, 2006 | 09:20 AM
DaBigTow's Avatar
DaBigTow
Virtually everything, except the intake, is a sealed system under the hood. However, that doesn't mean that a loose connection won't leak. Consider using a screwdriver or other appropriate tool to tighten clamps & fittings before washing. Also, remove the flip-top engine cover to gain access to the filter/pump area; this is alsways a gungy mess.
Old Jan 29, 2006 | 09:29 AM
1996pwrstrk
I have been putting the cleaning off, I don't think mine has ever been done boy it really needs it.I've no excuses now .
Thanks
Dave
Old Jan 29, 2006 | 11:28 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I just give it a good soaking with simple green and a garden hose. As those weatherpack connectors age, they don't always stay waterproof. I don't like a high pressure cleaning for that reason.
Old Mar 19, 2006 | 09:47 PM
CougarMark67XR7's Avatar
CougarMark67XR7
Engine Degreaser
There is a product called "Awesome" and it can be purchased at "Dollar Tree" stores for ONE Dollar. If you don't have a dollar tree store it can be purchased on ebay. It works great and it's cheap. Keep it off painted/plastic surfaces, rinse the fenders after you spray the engine. I would warm up the engine and then degrease it. Cleaned off all the blow by under the hood and makes aluminum shine like new, great for brake dust on wheels!! Good Luck!!
Old Mar 19, 2006 | 11:16 PM
RubberDuck's Avatar
RubberDuck
I agree with that except one thing. That simple green left a white haze all over everything. It cut the grease well. But after it dried, everthing looked like the threw baby poweder at it. Even after repeated rinses. I myself disliked that alot. I would try a different cleaner. But like Cookie said, just use a water hose. High pressure washing is risky on our trucks.
Old Mar 20, 2006 | 05:39 AM
1997F-350's Avatar
1997F-350
stay away from the IDM with water.
Old Mar 20, 2006 | 11:40 AM
1969fordguy's Avatar
1969fordguy
A pressure washer can damage stuff, for sure. One has to be careful when using it underhood. Foamy oven cleaner works quite well especially when mixed with some manual scrubbing!
Old Mar 20, 2006 | 11:44 AM
79f-250custom
Yes i finnaly got to wasing it when i took the pics and posted them. i went under there with a pressure washer and stayed away from the right hand side electrical stuff. it cleaned up half way descent now its time for the scrubbin. ill prob get some oven cleaner, awsome or some simple green and go out there 2 times a day and just blast the **** out of it for like a week. that should get everything loose and should wipe right off with some scrubbin.
thanks for the replys
Mitch
