Wicked wheel 2 on van
Old Oct 29, 2019 | 10:56 PM
octaneforce's Avatar
octaneforce
I have a 99 e350 7.3. Ive been slowly tinkering with it. Recently did a 4 inch full exhaust. The thing sounds nasty and it did uncork it a bit. Id like to get a little more turbo noise with the ww2 drop in turbo wheel. Faster spooling and more boost will just be a bonus. So im noticing some differences between the van and the pickups.
I know The vans have no intercooler. Do they have a wastegate? Im assuming it must have one but i dont see it on top of the turbo as obviously as i see them on pickups.
Tons of videos show guys taking the cold side of the the turbo housing off and then cracking the wheel loose with an impact gun. This avoids having to remove the entire turbo, but is it safe? The website says not to do that but an overwhelming amount of people seem to disregard the warning.
Can i delete that “exhuast flap” while im in there? Is it worth it?
Thanks guys. Not a ton of info on vans out there.
Old Oct 30, 2019 | 02:51 AM
FinnishStroker's Avatar
FinnishStroker
No wastegate in a van 1.15 turbine housing.
Personally i wouldnt use impact gun anywhere on turbo,but some say it's ok to loosen with impact BUT DONT tighten with it!
Some think you should fully balance your movin parts on turbo,but some say it's ok to add wheel that is component balanced.
Yes you can delete the ebpv flapper,but to get the full benefit you should do the non-ebpv pedestal.
Theres probably no performance gain in doing so,but the factory ebpv pedestal is proven to leak from the actuator rod.
By the way,i have 2000 e350 with custom stock turbo,been hitting 44psi boost with it..
Check my thread about it.
Old Oct 30, 2019 | 10:36 AM
z31freakify's Avatar
z31freakify
If you want to have a broken turbine shaft in the future then use an impact. Vans dont have a waste gate.
If you want to hear more turbo whistle upgrade your intake, I don't how that would be posible in a van. A tuner with decent tunes would wake your van right up.
Old Oct 30, 2019 | 11:16 AM
blageurt's Avatar
blageurt
Eliminate the CAT.....
Old Oct 30, 2019 | 12:38 PM
FinnishStroker
Custom "6637" intake is possible in a van,if you move battery elsewhere from under the hood.
Includes also some cutting and windshield washer reservoir fits under the fuse panel in engine bay.
Ive done all this,next im gettind rid of the ac compressor.(its ok in Finland)
I think intercooler would fit with some mods in front of the radiator,if theres no ac core..
Then some small hybrids and...
Old Nov 3, 2019 | 06:31 PM
octaneforce
In the exhaust? My stock exhaust didnt appear to have a cat. And the current 4 inch system is all straight pipe except 1 tiny muffler
Old Nov 4, 2019 | 07:16 PM
JOHN2001's Avatar
JOHN2001
If you have a straight pipe and put a van turbo on your truck I promise you, you will like the "ZZZIIIINNNGGGGGGGGG" that comes out of the exhaust when you let off while making boost!!!
Old Mar 7, 2021 | 02:18 AM
nlambuca's Avatar
nlambuca
I couldn't find that thread... how did you do it?
Old Mar 7, 2021 | 03:20 AM
FinnishStroker
https://www.ford-trucks.com/forums/1...63-4-80-a.html
Old Mar 7, 2021 | 08:37 AM
SkySkiJason's Avatar
SkySkiJason
Like they said, the compressor side of the van turbo is the same as the trucks. Vans have no WG and no intercooler and a larger 1.15 exhaust housing with a slightly larger turbine wheel. (Trucks use .84). The outlet adapter for the downpipe is also smaller on the van turbo. As long as you don’t have an ‘early 99’, everything else is the same as trucks. E99 vans got some weird stuff...
I describe how to eliminate the EBPV here for about $1. I don’t recommend buying a deleted pedestal.
https://www.ford-trucks.com/forums/1...lete-pics.html
I agree with the others’. Changing the intake will likely change the sound the most for you.
comadvan
Aug 17, 2016 11:20 AM
JOHN2001
Mar 10, 2013 04:01 PM
plgebbia
Feb 18, 2013 09:51 PM
bigpowerstroke
48
Jan 21, 2012 06:33 PM
tholt34
20
Jan 15, 2008 06:35 PM
