Thin Bedside Moulding Clips
Old Oct 19, 2019 | 12:08 PM
73GreenBean's Avatar
73GreenBean
So I'm starting to reassemble bedside mouldings and I have the thin narrow trim. I'm assuming the clips for wide and narrow trim are different and I also assume that the narrow trim clips are about as hard to come by as the narrow trim itself as it's not reproduced yet. Anybody know for sure if the wide trim and narrow trim clips are different?
Old Oct 19, 2019 | 12:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, the clips are different between the narrow and vinyl moulding.
Here's what you need for one side of the narrow moulding:
1) D2OZ-71425A94-A clip
1) 55946-S screw
7) D3TZ-16A076-A clip (2 use 38947-S nut and 5 use 45271-S nut)
11) D3TZ-9929318-A clip
1) D3TZ-16A076-B clip
1) D3TZ-9929318-B
Old Oct 19, 2019 | 12:54 PM
73GreenBean
1) 55946-S screw
1) D3TZ-9929318-B
I appreciate it! Found some on eBay and wanted to make sure before I buy any if I need them that they would be suitable. I have 99% of the clips just wanted to make sure I was thinking right that the vinyl and narrow took different sizes. Thanks again!
Old Oct 19, 2019 | 12:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes the normal/way more common and easy to acquire wide "dent" trim with the black strip moulding itself and the mounting hdwr is and easy locate. The thin "trim" only and the completely different mount hdwr is hard to locate. Like maybe some on here has some, but I have never seen it reproduced. Long or short bed?
Old Oct 19, 2019 | 01:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The thin upper body side mouldings were used on 1973/79 Rangers and some Customs, no one reproduces it.
I ran the three standard (hardware) part numbers Mike listed, Green Sales has 476 of 45271-A .. no one has the other two numbers.
73GreenBean
It’s for the 73 long bed Rich...I was hoping maybe you’d have a stash somewhere with all those FORD tailgate center panels you hoard
Old Oct 19, 2019 | 01:02 PM
73GreenBean
The thin upper body side mouldings were used on Rangers and some Customs, no one reproduces it.
Thanks Bill...looks like the junkyard or someone’s backyard is the only go-to in this situation
Old Oct 19, 2019 | 01:09 PM
fordguy2100's Avatar
fordguy2100
I may have some spare thin trim clips in my toolbox. I'll check when I get back home tomorrow or Monday if I forget lol
I only would have a few, I just sold a thin piece off the driver fender a while back but I think the clips are in my tool box
Old Oct 19, 2019 | 01:16 PM
73GreenBean
Perfect! I think I only need a few if any lol. Seems like I was maybe missing one or two when I pulled it all off 2 years ago...but I’ve seen every inch of this truck laying on the shop floor at some point so it’s hard telling what I know I have and what I think I have...
nisvec22
18
Nov 28, 2011 06:01 AM
bamafarmboy
Sep 20, 2011 09:05 PM
Aaron-71
Jul 4, 2011 10:22 PM
Samsonitesamsonite
May 2, 2004 07:37 PM
