remote keyless entry not working 2004 e250
Old Oct 9, 2019 | 07:26 PM
urko's Avatar
urko
I have a 2004 e-250 van. The inside locks work when I push the door button. When I try to use the fob nothing happens. I have changed the battery, checked the fuse and tried to reprogram the fob with turning the ignition 8 times. On the 8 time the locks engage, but the fob will not engage the lock. What else could be my problem. Not sure where to go.
Old Oct 10, 2019 | 09:03 AM
Philly driver's Avatar
Philly driver
A cheap solution would be to buy another fob in Amazon to check that the fob is not the problem. If it solve your problem keep it, otherwise return it for free.
Old Oct 11, 2019 | 03:16 PM
Teutonics's Avatar
Teutonics
I've posted this a few times, but I had the same problem on my '06. Ordered new fobs and those didn't work either. Unplugged the RKE module and let it sit overnight (disconnecting battery should do the same) and reconnected the next morning and all of the remotes worked! (new ones after programming). Two years later still no issues...So at least try that before spending any money. I now have four working remotes! LOL!
Old Oct 11, 2019 | 05:02 PM
urko's Avatar
urko
I do not think it is the fob. where is the RKE module located, I cannot seem to find it when searching for it or a replacement part.
Old Oct 12, 2019 | 08:54 PM
Teutonics's Avatar
Teutonics
RKE module is behind the trim panel just aft of the b-pillar behind the driver's seat.
Tomtmd
2004 - 2008 F150
Sep 8, 2019 08:57 PM
kink1950
Jul 9, 2011 05:39 PM
stokes86
Aug 19, 2010 12:18 PM
Aussie Jones
Nov 6, 2008 12:02 AM
waldreps
Dec 23, 2006 09:50 AM
