Sponsored by: Real Truck
keyless entry system not working
Old Nov 15, 2010 | 11:07 PM
kink1950's Avatar
kink1950
Tried to program keyless entry system and read the directions for a 2004 F350. Turn key off and on quickly and on 8th time doors should lock and unlock, but they don't. Am I doing something wrong?
Old Nov 16, 2010 | 09:15 AM
brd7666's Avatar
brd7666
Yes, you are doing something wrong. When I did mine it took a few tries. I put the key position in the middle between on and off, and started from there. It seems like there is a stopping point in the middle. You need to keep trying, and when you get it right, you will know, because the locks will lock, and unlock. Good luck.
Old Nov 16, 2010 | 11:01 PM
kink1950's Avatar
kink1950
remote entry
Tried it about 10 times in the past two days and wouldn't work. Tried it once today and it worked. Did nothing different. Thanks for your help
Old Jul 9, 2011 | 05:39 PM
fstanush's Avatar
fstanush
Kink, did you ever figure out your issue? I am having similar problem...not just with cycling ignition between 3 and 4 eight times, but the keyless entry on the door does not respond at all, so believe they are related...
May be fuse, but can't find one out or one direclty related to keyless entry operations.
By way, the keyless entry on the door is not the wireless with battery, it is original wired keypad.
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
medicpg
Jun 28, 2013 05:09 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
