Help me with vacuum lines
Old Sep 30, 2019 | 05:33 PM
JoshC017's Avatar
JoshC017
I recently picked up this 88 460 4wd. It used to be an automatic but now it's a manual. I don't know what all I'm looking at here, so please help me. I think I'm missing a vacuum like some where, cause it's running rough. When I first start it, it runs perfect for a few seconds then I have to pump the gas to keep it going for about 15 seconds then it idles ok. But running, it's rough.
Old Sep 30, 2019 | 06:20 PM
woodson84's Avatar
woodson84
I'm not an expert but I don't see any missing lines.
Look up how to read the codes, that'll help.
Old Sep 30, 2019 | 06:52 PM
sandymane's Avatar
sandymane
You have missing lines at the TAB,TAD and EVR solenoids. But first some info is needed.
Did you or the PO put the manual in? We need to know what kind of automatic was in there. Look on the driver door for your sticker that has a (TRANS CODE) and post that letter. Did you change the computer or do you know. Has it been running ok with the manual until recently or has it always been this way? These answers should help along with any history that may help also. Sandy
Old Sep 30, 2019 | 07:19 PM
JoshC017's Avatar
JoshC017
Code is K. I bought this truck like this. I do know that the guy that put it in had a full donor truck for all the manual parts. One would think he used the computer but who knows.
Old Sep 30, 2019 | 07:35 PM
sandymane's Avatar
sandymane
Code K is a C6 Ford Transmission. If it was an E it would be computer controlled and perhaps could cause the computer to be confused with the manual. With the C6 originally and now a manual I am not sure if the transmission comes into play with the computer which could effect a lot of things. Currently the vacuum lines should be on a diagram on a sticker under the hood. I would check them all and see what is there and what is missing. The three parts on the bracket in the center of the first picture are the parts currently missing vac lines. You can see the nipples where the lines goes.
Has it been running ok with the manual until recently or has it always been this way since you got it?
Old Sep 30, 2019 | 08:00 PM
JoshC017's Avatar
JoshC017
I've only had her for a couple weeks. Ran rough the whole time. It was used on a farm for the last 8 years. Regular care and maintenance where not a part of that farm.
What are those three pieces on the bracket for?
Old Sep 30, 2019 | 08:07 PM
sandymane's Avatar
sandymane
Let's run diagnostic codes and see what comes up. Even if you don't have a check engine light you can still have codes that can lead to your issue. In the video below he uses a jumper to test. You can just use a paperclip to do it. If you can let the truck idle to operating temperature you should do so before you run the test. Run the Key On Engine Off test KOEO. Let us know what codes you get.
Old Oct 1, 2019 | 09:31 AM
stonesg's Avatar
stonesg
Look for something like this under the hood... it may be covered in dirt.
If you can't find that, do a little google searching for the one for your truck.
Check that the EGR valve (if it's still hooked up) is not stuck open and and also check that there's a line running to the Fuel Pressure Regulator and that it's working properly.
If the EGR is getting straight vacuum without the vac solenoid hooked up (which I can see is disconnected) then it's open all the time and your truck will run like crap.
The person who gelded all the vac lines removing the emissions equipment may have disabled the FPR too thinking it was emissions related, when it's actually needed for the FI.
Old Oct 1, 2019 | 10:35 AM
JoshC017's Avatar
JoshC017
I don't have that sticker under the hood. I've searched a good bit for a diagram, but I can't find anything conclusive. And when I think I've found the right one, I can't even read the darn thing.
Old Oct 1, 2019 | 10:38 AM
JoshC017's Avatar
JoshC017
https://www.youtube.com/watch?v=p04NPv_gXsI&t=19s
I thought i'd try it while it was still cold, so I could also search around for the vacuum stuff. I think i have it, but I'm not sure. From the video, the (1) indicates a space or pause in the codes. In that case, the first part of the test I got a 3 2 8. The second part seemed to go on for ever and I'm not sure I even got it all, but it was 8 2 8 5 8 4 3
Old Oct 1, 2019 | 10:41 AM
sandymane's Avatar
sandymane
I am pretty sure you are only going to have two digit codes. The newer trucks have 3 digit codes.best thing to do is hook it up get in there and give it a try
Old Oct 1, 2019 | 11:05 AM
stonesg's Avatar
stonesg
Here's a possible one:
TheGreat460
May 11, 2020 03:25 PM
powerstroke7367
Aug 12, 2019 02:40 PM
fstbck1970
Aug 10, 2017 08:13 PM
Wolfmancc
1978 - 1996 Big Bronco
Oct 6, 2015 01:22 PM
Patrick Musick
Jan 30, 2015 12:40 PM
