vacuum help
Old Jan 29, 2015 | 02:54 PM
Patrick Musick's Avatar
Patrick Musick
vacuum help
hey have a 83 f100 l6 4.9l single barrel carb
im having a little confusion with the vacuum line attached are some photos
the one is numbered I need to know what each port is or is for so I can run the vacuum lines to them
Old Jan 29, 2015 | 06:11 PM
Franklin2's Avatar
Franklin2
Something doesn't look right. That's not the original engine is it?
Old Jan 29, 2015 | 06:44 PM
Patrick Musick
From what i know of it is
Old Jan 30, 2015 | 11:23 AM
JimsRebel's Avatar
JimsRebel
On the first pix, that is the WOT, it is used with the EGR to disable it when you floor it.
WOT = wide open throttle
Looking at the vacuum diagram photo in the lower left corner on the same line as DUAL TANKS it should say 4.9. It is cut off in the photo.
Is the Dist "Dual Vacuum"?
Is this a Calif truck?
I would edit the post title to include...... 1983 4.9 - Photos needed of vacuum lines.
Good luck, Jim
Old Jan 30, 2015 | 12:40 PM
1986F150six's Avatar
1986F150six
Okay, I think I can help with some... Keep in mind that my engine has been desmogged [Duraspark conversion].
Using your numbering system from the photo at the top of the thread...
1. I believe this is ported vacuum for the distributor vacuum advance.
2. ? All I see is a hose and cannot tell where it is connected. [PVC hose connection]
3. This port is the vacuum source for the junction mounted on the firewall which then is connected to the ventilation system.
4. This was connected to the emission system - now capped on mine.
5. ?
6. This port supplies vacuum to the temperature sensor located on top of the air cleaner.
What is missing is the PCV hose connection. This is a large rubber hose [similar to the PB booster line]. On mine, it connects to a large vacuum port located at the base of the carburetor. Now that I look again, I believe #2 is for a somewhat hidden port which will be the PVC connection.
I hope this will be of some assistance!
Last edited by 1986F150six; Jan 30, 2015 at 12:43 PM. Reason: Added to the PVC port location.
TheGreat460
May 11, 2020 03:25 PM
powerstroke7367
Aug 12, 2019 02:40 PM
mmmmoore24
Jun 25, 2014 02:57 PM
6fifty_f1fifty
Dec 24, 2009 01:02 AM
polaris21
Jan 21, 2009 11:49 AM
