I have a 95 f150 4.9l 4x4, my question is on my 4wd indicator light. All lights are off in 2wd and neutral but it shows 4 low in both 4wd positions. It is a floor shift transfer case e4od transmission
The low range light is separate from the 4wd so it should not be on at all when it's in the 4 hi position but it is.
I don't have the wiring diagram but you can bet there's a switch of some sort for turning those lights on and off.
Mechanical switches fail open or closed depending on a variety of factors and design considerations.
If the bulb is on when it shouldn't be there could be a linkage to switch issue or just a switch issue.
From the sounds of it, if you find the switch you'll find your problem.
