Vacuum help needed!
Old Feb 13, 2017 | 05:25 PM
TheGreat460's Avatar
TheGreat460
Vacuum help needed!
I have a 93 460 4x4 e40d. I had a rat get in and chew some vacuum line up and I'm still struggling to repair all them. I checked the vacuum diagram and didn't get much help from that. The lower one goes to the vacuum reservoir. But the rest I have no idea. This line is just right of the egr valve.
Here's an up close.
I believe one connects to this for the air system. Not sure though.
and understand how to repair the colored lines: pink, red, white. But there's a few that have me at a loss.
As you can see I put a nipple over each port to stop the leak. But I would like to fix it properly. I have no idea where these go and can't seem to figure it out from the vacuum diagram. The 3 ports in the picture are located directly behind the distributor. Any help would be greatly appreciated.
Old Feb 13, 2017 | 09:08 PM
vjsimone's Avatar
vjsimone
So your vacuum diagram should show that you have these devices connected to vacuum. Find these devices, and see that they are connected.
MAP SENSOR -bk
AIR CLEANER - bk/y
SPEED CONTROL - bk/br
BRAKE BOSTER - by/y letters
DISTRIBUTER - red
TRANSMISSION - bk
CHECK VALVE - bk
SOLENOIDS - pk
If you check your codes, you may get an idea of what devices are affected by no vacuum connection.
Old Feb 13, 2017 | 10:43 PM
TheGreat460
Thanks for your help! I'll take a look tommorow.
Old Feb 14, 2017 | 07:36 AM
subford's Avatar
subford
The Vacuum tank for the emission system should be like this:
The vent system vacuum tank and check valve should look like this:
The outside air vacuum motor with a white vacuum line:
The emission vacuum diagram should look like this:
And the 1993 Vent vacuum system:
Old Feb 14, 2017 | 10:30 AM
TheGreat460
Thank you so much this is a world of help. I think I have a good idea of what needs done now. I will pick up some lines next time I head into town.
Old Jan 8, 2020 | 08:24 PM
97vanswap's Avatar
97vanswap
help me out i know its old thread.where does brake booster vacuum line connect to???
Old Jan 8, 2020 | 09:19 PM
torq'ta 5 8's Avatar
torq'ta 5 8
may not be much help, but it should go to the biggest port on vacuum tree, brake booster vacuum hose is 3/8, the rest are smaller in comparison
Old Jan 8, 2020 | 09:27 PM
97vanswap's Avatar
97vanswap
i think i may have found the secret hidden port but not going out now.its dark and freezing..
Old Jan 8, 2020 | 09:31 PM
vjsimone's Avatar
vjsimone
Example of Vacuum Trees;
Old Jan 8, 2020 | 10:00 PM
97vanswap's Avatar
97vanswap
yes thanks i found that same pic with a google search. i believe its figure 8. you would never know its there if it is there. found a pic off ebay i hope its there and the problem.
Old Jan 8, 2020 | 10:19 PM
97vanswap's Avatar
97vanswap
well couldn't wait. yes i found the magic tree. every hose is off it tree is completely open., i think that's going to be my problem! ..i hope. man its so tight in there its going to be fun trying to get in there to plug it up.!
Old Jan 8, 2020 | 11:14 PM
97vanswap's Avatar
97vanswap
thanks vjsimone! i found your old post from 2016. underhood sticker is worthless.
https://www.ford-trucks.com/forums/1...-5l-460-a.html
Old May 11, 2020 | 03:25 PM
red08mlb's Avatar
red08mlb
just curious...
can you remove the fender liner and gain access to the resv?
mwilliams0326
Jul 27, 2017 09:32 AM
JakefromStateFarm
Feb 12, 2016 03:41 PM
joedirt1971
Nov 25, 2015 08:14 AM
Patrick Musick
Jan 30, 2015 12:40 PM
bsr2002
Aerostar
May 23, 2010 05:00 PM
