1966 - 1977 Early Broncos
Flex plate bolt ring
Old Sep 26, 2019 | 04:53 PM
wgb's Avatar
wgb
Does the C4 flex plate use a reinforcement ring when bolting to the crank shaft? I have what I believe to be a '73 C4 in my '71 Bronco and am installing a 302 from (I believe to be) a '74 Bronco. The engine came with no flywheel or flex plate. I am familiar with flex plates that use a reinforcement ring between the bolts and flex plate (some are part of the flex plate, and some are a separate part). Not familiar with the 302/C4 arrangement. Flex plates I find on line appear to not have the reinforcement ring on them. Is one needed for this combination?
Thanks for wisdom from those who know what I am talking about.
Old Sep 27, 2019 | 03:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Sorry I do not know the answer. And if you can not get an answer here, you can ask these EB folks. There is a TON of experience on that site. I get a lot of help there myself.
Main page. https://classicbroncos.com/
Message forum. https://classicbroncos.com/forums/index.php
High76boy
Jun 10, 2013 03:45 AM
drewdole
Feb 26, 2013 08:16 PM
0351mike
May 1, 2010 05:54 AM
RICHMC54
May 30, 2004 09:28 PM
GEAH
Sep 4, 2002 05:19 PM
