Flex Plate Question
Old Sep 4, 2002 | 11:33 AM
GEAH's Avatar
GEAH
Flex Plate Question
Im putting together a 86 302(the 302 had an AOD behind it) and a 1978 NP435 with a Clutch assembly from a 78 1/2. I need a flex plate that will work with this setup and I seem to only be able to find the ring gear. I've been told that one from an F150 from 1973-79 will work. Does anyone know of any other year that will work. Or where I can order something that will work.
Old Sep 4, 2002 | 03:23 PM
Franklin2's Avatar
Franklin2
Flex Plate Question
You had better get a flywheel from a later model for balance reasons for the 86 motor.
https://www.ford-trucks.com/dcforum/80_96/7643.html
Old Sep 4, 2002 | 04:41 PM
Jimbare's Avatar
Jimbare
all alone in the world
Flex Plate Question
you need a flywheel not a flex plate. flex plate is for an automatic, flywheel is for a standard. you will need one with the 50 counterweight. i beleive it is used on 85 and up 302. i think 351 windsor is also the same 85 and up.
Old Sep 4, 2002 | 05:19 PM
Fordmanwithacause's Avatar
Fordmanwithacause
Flex Plate Question
