flex plate
Old May 30, 2004 | 10:33 AM
RICHMC54's Avatar
RICHMC54
flex plate
converting 3 speed to c6, was told I would need a flex plate spacer, engine is 302. also was told just bolt flex plate to engine. have no clue.
Old May 30, 2004 | 10:48 AM
fellro86's Avatar
fellro86
just need flywheel (flexplate) and bolt up.
Old May 30, 2004 | 10:55 AM
RICHMC54's Avatar
RICHMC54
flex plate
thanks you ever heard of a flexplate spacer
Old May 30, 2004 | 09:28 PM
fellro86's Avatar
fellro86
yes, generally they are used for cases when an adapter plate or mid plate are used. Also, sometimes you can get a balance plate for use on motors needing external balance with a flexplate or manual flywheel that is not. They may have been referring to the washer plate that is sometimes used behind the flexplate, but not between the flexplate and crank.
