Side mirror defrost button location
Old Sep 7, 2019 | 04:56 PM
fordman19762003's Avatar
fordman19762003
Have a 2019 STX with the defrost for the side mirrors but I can't find the switch. Do they come on automatically when you turn on the rear defrost? The mirrors have the defrost icon on them so they do have the feature. I've looked in the book and the truck and can't find it.
Old Sep 7, 2019 | 05:25 PM
Dieseln00b's Avatar
Dieseln00b
Incorporated with the rear window defrost button? - I have a 2019 as well and haven’t had to use it yet but assume it’s there
Old Sep 7, 2019 | 06:08 PM
vancouverbrian's Avatar
vancouverbrian
I own a 2017 F350 Lariat 6.2l and I did not know the answer. So I went to the truck and read the owner's manual. It says this....When you switch on the heated rear window button, it activates the heated mirrors also. Make sure the engine is running, and it the button is located on the center console in the climate control areawith 3 wavy lines and R on it. I hope this helps.
Old Sep 7, 2019 | 07:08 PM
fordman19762003
Thanks, I must have missed that part of the manual. I figured everything was run off the rear window defrost button.
Old Sep 7, 2019 | 07:41 PM
vancouverbrian
sorry. I was only quoting the book. I think it is that button. The rear window defrost button. I just like to get things exact and quote exactly correct. But you are correct.
Old Sep 7, 2019 | 07:53 PM
wylecoyote's Avatar
wylecoyote
I was looking for mine today also. Just picked up the truck Thursday. What I found was if you turn the defroster on high, the mirrors warmed up also. Havent tried the rear defroster yet.
Old Sep 7, 2019 | 08:39 PM
edjunior's Avatar
edjunior
Page 149 of the "2019-Ford-F-250_350_450_550-owners-manual-version-1_om_EN-US_05_2018" describes the "Heated Exterior Mirrors". This can be downloaded from the Ford Owners website.
Old Sep 16, 2019 | 10:20 AM
HRTKD's Avatar
HRTKD
The rear heated window and heated mirrors are both on the same fuse (#17).
The manual says:
When you switch the heated rear window
on, the heated exterior mirrors turn on.
SuperTrooper641
2015 - 2020 F150
Mar 30, 2025 03:24 PM
makthenif
May 31, 2011 04:04 PM
69ford99
2004 - 2008 F150
Feb 11, 2008 09:28 PM
beetlebarn
Dec 10, 2003 10:37 AM
89CrewCab
Jul 31, 2003 03:39 PM
