Drivers mirror keep moving from memory setting
Old Oct 11, 2017 | 08:31 PM
SuperTrooper641's Avatar
SuperTrooper641
I have a 2015 F-150 Lariat with memory seats and what seems like every other time I start my truck, the drivers mirror moves up and left just a little away from the memory position. I can either self adjust it back or if I notice it before I put the truck in drive, just hit the # 1 memory button and it will move back to where it is suppose to be. I have had the dealership do a "Reset" of the mirrors 3 times but it always starts self adjusting again. The only thing I can think that may be causing this is that I do use the button to fold in my mirrors sometimes pulling up at a drive thru or when parking trying to make sure that if someone walks by they do not hit my mirror walking between the vehicles.
I will not stop using the button to fold in the mirrors as Ford designed them to do when I need to but I am not going to continue to put up with the mirror self adjusting either.
My dealer seems to be at a loss as what to do next.
Thanks in advance.
Old Oct 11, 2017 | 09:20 PM
JKBrad's Avatar
JKBrad
See if they will replace the switch. When I had a problem with my Super Duty mirrors, it was the switch. 5 minute fix. If that doesn't work then I would suspect the memory module.
Old Oct 12, 2017 | 05:26 AM
rmccbride's Avatar
rmccbride
Thanks in advance.
Are you sometimes using the key pad to unlock the doors and the FOB other times? Are they both programmed the same? Why aren't you using Forscan to automatically fold the mirrors when locking the truck? Makes it very handy for me as I always like mine folded and have a hard time remembering to do it before turning off the truck.. Also makes it easy to look out the kitchen window to make sure the truck is locked, mirrors folded equals truck is locked..
Old Jun 16, 2018 | 09:24 PM
Fluiddude's Avatar
Fluiddude
Any luck
The EXACT same thing is happening to me. Did you have any luck with this?
Old Feb 15, 2025 | 08:47 AM
Howie Tyson's Avatar
Howie Tyson
I have a ‘15 Lariat and mine does the same or very similar. When I get in and start up, the wheel, seats and mirrors start adjusting as they should. The passenger mirror is almost very close or right on to where I have set it. The driver mirror is always just slightly off, most of the time just a bit higher or farther out from where I have saved it. I have Lincoln mirrors enabled and use easy entry exit enabled in the IPC. It is very annoying for me as well.
Old Mar 24, 2025 | 05:45 PM
lwk362393's Avatar
lwk362393
Giving this another bump as I have the same problem in my ‘19. Would love to know if the OP ever got it resolved.
Old Mar 25, 2025 | 10:04 AM
KJ Smith's Avatar
KJ Smith
I had this issue with my '13.
I now have it with my '17.
I just live with it.
Old Mar 25, 2025 | 10:34 AM
scott91370's Avatar
scott91370
@lwk362393
There is a fix:
SSM 49217 -
2015-2020 Edge/MKX/Nautilus/F-150/Mustang - Mirror Click And/Or Ratcheting Noise - Built On Or Before 18-Jan-2020
Some 2015-2020 F-150/Mustang, 2016-2020 Edge, 2016-2018 MKX and 2019-2020 Nautilus vehicles built on or before 18-Jan-2020
May exhibit a mirror click and/or ratcheting noise when using memory functions or easy entry/exit function. This may be due to the software in the driver door module (DDM) and passenger door module (PDM). To correct the condition, reprogram the DDM and PDM with the latest software level of the appropriate Ford diagnostic scan tool. For claiming use causal part 14B291 and applicable labor times in Section 10 of the Service Labor Time Standards (SLTS) Manual. APPLICABLE VEHICLES 2016 - 2020 CAR: DQ CD539N EDGE 2015 - 2020 TRUCK: FC P552N F-150 2015 - 2020 CAR: ZG S550N MUSTANG 2016 - 2020 CAR: D9 U540N MKX
Old Mar 30, 2025 | 03:24 PM
lwk362393's Avatar
lwk362393
Thanks. I had the clicking/ratcheting issue too, which was fixed with a reprogramming. This is unfortunately different.
Plink
22
Jun 9, 2025 12:06 PM
EightySecond
Oct 17, 2020 07:23 AM
Darran Graham
Dec 22, 2017 11:09 PM
Joshua Deeds
Jul 24, 2017 06:43 AM
beetlebarn
Dec 10, 2003 10:37 AM
