Lost my key!!
Old Sep 15, 2019 | 09:22 PM
projectSHO89's Avatar
projectSHO89
Yes, of course. That's not the premise of the OP, though, as he allowed himself to get in a position where he only had ONE. That situation requires one to take either the "correct" measures of getting more and re-programing all of them with an appropriate scan tool or equivalent or to take alternate action to get by. He chose the second action.
Old Sep 16, 2019 | 09:27 AM
alloro's Avatar
alloro
Originally Posted by tbear853
Y'all do know that you can get chipped key blanks new, uncut …. have them cut to match …. and with at least TWO programmed keys in hand,
Be aware here that they have to be two different and unique coded keys and one cannot be a clone of the other. Using a cloned key would be the equivalent of using the same key twice.
Old Sep 16, 2019 | 10:55 AM
canstacker's Avatar
canstacker
Yep, you are right 8 unique coded keys. But you can have as many cloned keys as you want? This is covered in the sticky:
https://www.ford-trucks.com/forums/9...ts-info-5.html
Old Sep 17, 2019 | 08:43 AM
steve(ill)'s Avatar
steve(ill)
A clone key gives you a second key with the same CODE as the original.. The CLONE will start the truck using the original code number.. It can NOT be used as a second key to program additional keys... Sometimes the CLONE cost as much as getting a new key and doing it RIGHT.
toys4dlr
Sep 21, 2024 06:44 AM
Mark 42
Mar 9, 2018 02:28 PM
tseekins
2009 - 2014 F150
Dec 20, 2015 10:55 AM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
Monju123
2004 - 2008 F150
18
Oct 2, 2006 11:10 PM
