Programing PATS key
Old May 21, 2006 | 08:08 PM
Monju123's Avatar
Monju123
Programing PATS key
I very recently bought a new 06 F150 scab. I wante a 3rd key cause, well, I wanted a 3rd key. I went to the dealership with the 2 keys in my hand. I was told it would take several hours & $130 . When I asked if I couldn't program the key myself, I was told you need 3 keys to program them yourself. I know that 2 used to be the magic number of keys needed. Has this changed with late models. I wanted to call them lying SOB's , but wasn't sure of my facts.
BTW, it was Champion Ford on the Katy Frwy, Katy Tx.
Old May 21, 2006 | 08:23 PM
Ford Fx4's Avatar
Ford Fx4
No you only need 2 keys to program the other.
Old May 21, 2006 | 11:15 PM
cool guy's Avatar
cool guy
it took me about 30 seconds for programing 2 keys......you're right they are a lying sob.....besides it only cost me 36.00 dollars for those 2 extra keys......
Old May 22, 2006 | 06:23 AM
wildcard30's Avatar
wildcard30
Here's the procedure to add a key. You must have 2 working keys to do this. The info comes from Ilco blank key reference catalog.
Add Duplicate Key (Requires two working keys)
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within five seconds, insert a second key and
turn it to ON (RUN) then back OFF.
4. Insert the new key before ten seconds have elapsed and turn it to ON
(RUN). Leave it on for one second and turn back to OFF.
5. The security light will light up for three seconds to indicate that the new key
has been successfully programmed.
Old May 22, 2006 | 06:06 PM
orgnova's Avatar
orgnova
only need 2 keys to program, got my keys off ebay for $12 each, had them cut at the local hardware store, no charge, easy to program.
Old Jun 27, 2006 | 06:36 PM
garvicmos's Avatar
garvicmos
from-garvicmos New to the site, very impressive! as to the key thing what if you only have one? My pickup is a 04 F150
Old Jun 27, 2006 | 06:47 PM
Beast12's Avatar
Beast12
Hi garvicmos and welcome to FTE! You have to go to the dealer to get a second key programmed. I believe it is around $100 for the key and programming. Good luck!
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
Old Jun 27, 2006 | 06:48 PM
wildcard30's Avatar
wildcard30
Time to see the dealer! You need both keys to add anymore....
Old Jun 28, 2006 | 07:08 AM
keith Ruge's Avatar
keith Ruge
Thanks for the post wildcard30
Old Jun 28, 2006 | 07:38 AM
projectSHO89's Avatar
projectSHO89
A very well equipped locksmith can also do this.
The NGS for the locksmith would have set him back around $2500, so you'll have to look around for one that has the system.
Steve
Old Sep 29, 2006 | 09:19 AM
Wandrey1's Avatar
Wandrey1
PATS keys for 2003 explorer Ltd?
We just bought a used explorer Ltd and picked it up last night we were supprised that there was only one key and one remote. The dealer is trying to contact original owner - I see now that this may be more important than I thought the 2003 exploere probably has the PAT? We were hoping the dealer separated the keys so for extra safety so they dont looks them UG $100 to program a blank ? wow
Old Sep 29, 2006 | 11:40 AM
sprucetree's Avatar
sprucetree
My local dealer charged $65 to program a new key.
Old Sep 30, 2006 | 08:41 PM
xtrm1stang's Avatar
xtrm1stang
it cost me $2500 to program my keys, but that included my very own PDS. anyone in the centraL FL area need keys programmed? less than dealership!!!
Old Sep 30, 2006 | 09:55 PM
Wandrey1's Avatar
Wandrey1
Feedback from dealer -Positive
E-mailed my dealers service manager and asked for a quote to program a single pre cut PATS key.
He left me a voicemail at home - $37.95 Not as bad as I figured
Found two New Blanks on Ebay from locksmith out of Charlotte NC for $34 including shipping so here we go ...
Figured I would get the keys cut at hardware store
Get One key programmed at dealer
Program the 2nd at home
Stash one of them in a lock box !!
After I get this done I'll FW the dealer info - want to make sure they come through first
Thanks for all input to date
Ken
Old Oct 2, 2006 | 06:13 PM
xtrm1stang's Avatar
xtrm1stang
they should not charge any more to program one or two keys
