Upfitter switch wiring
Old Oct 15, 2019 | 10:24 AM
PentaPop's Avatar
PentaPop
I haven’t seen anything like that. I just used that plastic split loom stuff and ran the wires across near the hood gasket. Nice, neat and out of harm’s way.
Old Feb 17, 2020 | 03:47 PM
BrianOTM's Avatar
BrianOTM
6th Gear
The wires are now on the passenger side under the hood - better to mate up with the pass through wires under the passenger kick plate.
Good luck
Brian
Old Mar 26, 2020 | 02:16 PM
robdog6942's Avatar
robdog6942
TPMS
My buddy has a 2018 F450 and doesn't have TPMS, what did you use for your TPMS?
Originally Posted by scottz99
Just picked up a new F450 and I'm installing my trailer back up cam, TPMS and dash cam (the F450 does not have tire pressure sensors and the "ultimate tow package" trailer back up camera is not as Ford led me to believe).
I was looking for a key on power source (found one) and wanted to check out the upfitter switch wires; can't find them. I found a bundle of wires in the passenger kick panel area and another set of 4 wires, but the label and colors do not match the information in owners manual. I read that they may also be in the engine compartment near the upfitter relay box. Do they appear in both places? Where are they in the passenger kick panel as the owners manual says?
Thanks
Old Jan 5, 2021 | 11:41 AM
Shane Schuiteman's Avatar
Shane Schuiteman
Originally Posted by SDcrewzer
I believe the “other bundle” is the harness for the stationary elevated (engine) idle control (SEIC) for power take-off (PTO) applications.
Link to application bulletin: https://madocumentupload.marketingas...013b9&v5=False
The GN/OR wire appears to the be the “Hot on Start or Run” +12 source for the upfitter switches and relays, but not for their loads. I’d probably use an upfitter switch and relay output circuit instead.
HTH,
Jim / crewzer
The upfitter aux 1 is where my pto is located and it keeps turning the truck off when engaged.. Its worked previously but for some reason now is shutting truck off. Anyone have any ideas?
bbronco66
Nov 9, 2024 06:50 PM
JDJR59
Feb 14, 2024 01:09 PM
Rick Cargo
Sep 20, 2020 03:05 PM
dreneer
Oct 17, 2019 01:22 PM
DAFBFD58
Apr 26, 2019 12:10 AM
