Upfitter Switch
Old Mar 22, 2019 | 02:16 PM
JDJR59's Avatar
JDJR59
Upfitter Switch
Taking delivery on a 2019 F250 with upfitter switches. Are the wires already connected and threw the fire wall? My 2016 had to be connected under the dash
Old Mar 22, 2019 | 02:35 PM
ForCal's Avatar
ForCal
I believe they are behind the passenger kick panel and in the engine bay.
Old Mar 22, 2019 | 02:44 PM
Mass-n-Trash's Avatar
Mass-n-Trash
They are wired and powered under the driver's side hood hinge (below fuse block), If you want to run switched power to the inside of your truck, you simply find one of those same wires and connect it to (run a wire to) one of the "pass through" wires in the cab. The pass through wires are under the passenger side hood hinge ( near fire wall) and come out behind the passenger side kick panel next to your right foot.
Old Mar 22, 2019 | 04:10 PM
thewholetruth's Avatar
thewholetruth
yes, they are hot/switched and connected to the upfitter switches already. They can be spliced/found near the driver side firewall under the hood. They also have ignition keyed and always-hot wires included in the bundle. All are labeled and there’s a PDF floating around this forum with the schematics too.
I did not know about the pass-through wires on the passenger side mentioned below but that’s great to know too.
Old Mar 22, 2019 | 04:12 PM
thewholetruth
post #3 here has the PDF schematics
https://www.ford-trucks.com/forums/1...al-source.html
Old Mar 22, 2019 | 08:50 PM
CPal's Avatar
CPal
Also the pass thru wires are short as hell, be prepared for some aggravation. Heaven forbid they give you a couple extra inches.
Old Mar 22, 2019 | 11:42 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
That's what she said?
Old Feb 13, 2024 | 12:23 PM
Tim Murray's Avatar
Tim Murray
4wd Low
They are hot already? Huh?
Old Feb 13, 2024 | 12:43 PM
longhaultransport's Avatar
longhaultransport
Yes, the wires under the hood, under the upfitter relay box are already hot. The color codes match up to the switch number.
If you want to power something inside the cab, use the pass through wires provided.
Old Feb 13, 2024 | 12:48 PM
Tim Murray's Avatar
Tim Murray
4wd Low
Ah, I misread it. Though you were referring to inside the cab. I can't find the pass through wires. There are a hundred videos on YouTube and none that clearly show where the pass through wires are located under the hood. About to remove the battery since that's one option. 2021 F-350.
Old Feb 14, 2024 | 12:41 PM
Bugzilla46310's Avatar
Bugzilla46310
Mine (2023 F350) are under the upfitter relay/fuse box all taped up. Found them after I removed the battery box that a 2033 Ford document said they were located under. The Ford body build document is a good resource though I find discrepancies in that also.
Old Feb 14, 2024 | 01:02 PM
Tim Murray's Avatar
Tim Murray
4wd Low
I spent two hours looking and gave up. Ford was no help.
Old Feb 14, 2024 | 01:07 PM
4wd6.7L's Avatar
4wd6.7L
Looking for pass-through wires, or upfitter wires?
Old Feb 14, 2024 | 01:09 PM
Tim Murray's Avatar
Tim Murray
4wd Low
pass through
Rick Cargo
Sep 20, 2020 03:05 PM
orion1968
Mar 11, 2019 04:39 AM
Boatdude60
Sep 12, 2018 09:30 AM
rustyshakelford
Nov 29, 2016 03:28 AM
davidmcintyre
6.7L Power Stroke Diesel
Sep 4, 2010 09:53 AM
