67/72 Windshield purchase.
1967/72 F100/750 weatherstrips (with/without reveal mouldings) are not the same as the 3 types of weatherstrips used on 1973/79's.
1967/76, 1977 before serial number O80,001 use the same stainless steel windshield reveal mouldings.
Mine does have the chrome and if anyone wants to share install tip please do.
Heres something I didn’t know, the windshield had what looks like butal tape around the weatherstripping. Has anyone every put one in without using any sealant.
Thanks
https://www.ford-trucks.com/forums/1...rome-trim.html
https://www.ford-trucks.com/forums/9...tallation.html
I did my '58 chev pickup and it has one of the harder glass shapes to do.
Here's how we do it on our Dents:
'67 or earlier remove your inner rear view mirror and maybe your outside ones too. (they get in the way and walking around the open doors 50 times is enough of a challenge)
There is NO sealant required. Clean the pinch weld opening real good. Paint it maybe?
Make up a couple spray bottles of soapy water.
Get a couple of step stools.
You need enough 3/16" nylon rope or telephone cord to go all the way around the windshield perimeter plus 2 ft.
Get a good buddy to help (this is 3 hrs minimum.)
Save the beer on ice until later.
Lay the windsheild face down and install the gasket with the trim pieces in the gasket. Tape it to the glass in several places (20?) with masking tape to hold it all together.
Push 3/16" nylon rope or telephone cord in the pinch weld slot starting at the center top and toward both sides, ending up at the center bottom with two tails of rope.
Now both of you grab a side and carefully (from the outside) start the bottom edge of the gasket onto the lower pinch weld. Center the whole assembly as best you can.
From INside the cab pull the rope tails a little at a time out of the bottom slot to allow the pinch weld to go into it's slot where the rope was.
Continue this pulling a bit of rope out of the gasket toward both sides of the cab. (And use liberal amounts of soapy spray to make it slippery.
Go very carefully especially when you get toward the doors.
There is a funny technique that involves slapping on the windshield with your hand (SLAP SLAP SLAP) to sort of jiggle the gasket onto the pinch weld.
(I never did try those "suction cup grips" but they could be useful.)
Continue working the pinchweld into the gasket and laying the glass back into the opening making sure that it stays seated at the bottom. Of course pull the masking tape off as you go.
Guys with the stainless trim keep tweaking it into it's groove.
Of course when you get to the middle at the top you are going to have a bunch of rope in the cab and every thing should be wet with soapy water.
So if all goes to plan you shouldn't need any sealant. (I Iive in Oregon where it is a test bed for windshield leakage.) Two years not one drop.
BTW I used the LMC gasket.
I have seen guys use some 3M caulking black butyl rubber and a skinny tip to go from the outside under the edge into the glass slot only, but it's messy and would be hard with trim.
Now
.If you do this job from anyone's instructions like mine or whoever then guess what!! Now two more guys know how to do it. And they can teach others.....
Also if you decide to go without the Trim pieces it's a bit easier since you don't have to fuss with keeping it in it's slot all the time. But you have to commit to which way (trim / no trim) when you buy the rubber gasket as they are different.
