Is this a normal piston?
Old Aug 10, 2019 | 11:15 AM
67 StylesLide's Avatar
67 StylesLide
For a Inline 300. Does it look to be standard or higher or lower compression???
I'm thinking of buying a machined block and parts from a guy who no longer wants to use them.
Old Aug 10, 2019 | 11:32 AM
FuzzFace2's Avatar
FuzzFace2
He did not know what they were?
Did he know who made them or if for a standard or over bore block and by how much?
What is the mark on the top of the piston?
As a WAG I would say stock because of the dish but I am far from an expert
Dave ----
Old Aug 10, 2019 | 11:35 AM
67 StylesLide
Bored .060" over
It's out of town.
Old Aug 10, 2019 | 04:22 PM
FuzzFace2's Avatar
FuzzFace2
Is your block that worn out that it needs to be bored 60 over?
I know some motors when you start getting that much they start to run hot and 60 is the last step before scrapping the block.
Again not an expert but something to keep in mind on 60 over pistons for any motor.
BTW might want to post this same question & picture in the 240 / 300 motor area as I am sure someone there will know like French town flyer as he races the 300 six motor.
Dave ----
Old Aug 10, 2019 | 07:10 PM
67 StylesLide
XLNT advice Fuzzface. will do
Old Aug 11, 2019 | 01:27 PM
old28's Avatar
old28
.060" over bore on a 240/300 motor usually causes motor to run hot. It also makes the piston bore walls very thin, right on the edge. If you go the .060" overbore be sure to have the piston bore wall in the block sonic tested for thickness before you start rebuilding.
