Sponsored by: Real Truck
Shift lever is tight
Old Aug 2, 2019 | 05:37 AM
rmo5095's Avatar
rmo5095
I have a 2000 F350, I see a lot of post for shift levers being loose but, mine is the opposite it seems abnormally tight. It shifts into place fine just seems tight , is there a bearing in column or lube point to address this, thanks!
Old Aug 2, 2019 | 05:52 AM
Jakerichards1's Avatar
Jakerichards1
Typical symptom of old shift indicator
On side of trans where shift rod goes into transmission there is this thing I think it’s shift indicator or neutral safety switch.
Tells trans electricity which gear you have selected. It gets really stiff until you can’t tell which gear your in
Last edited by Jakerichards1; Aug 2, 2019 at 05:54 AM. Reason: Pic didn’t work cut paste
Old Aug 2, 2019 | 07:52 AM
projectSHO89's Avatar
projectSHO89
Disconnect the cable at the transmission and see if the the shifter is still too stiff to operate. If it operates freely now, most likely the transmission-mounted shift lever position switch is gummed up internally. Remove it and test, replace if it's the cause of the problem.
Old Mar 11, 2022 | 09:29 AM
jefflondon's Avatar
jefflondon
Good morning! now that I've got the beast running again - working on the smaller issues. The shift lever feels really stiff / sticky - trying this test today - Just wanted to say thank you AGAIN
Old Jul 30, 2023 | 09:05 PM
Loose_Nut's Avatar
Loose_Nut
4th Gear
It's a neutral safety switch/shift position sensor, I just changed the one on my 03 Super Duty. Sometimes they can be a real pain in the a..oops no bad language. Bad Toad!
96firephoenix
Mar 13, 2018 09:14 AM
rexblue
Apr 19, 2015 08:29 AM
acom01
Jun 24, 2010 06:57 AM
midnight_mp
Jan 20, 2008 05:30 AM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
