Shift Lever Issue
Old Apr 18, 2015 | 08:33 AM
rexblue's Avatar
rexblue
Shift Lever Issue
Good morning.
The 3spdOD in my '65 works fine and is getting smoother to shift now that it's getting broken in and lubricated.
The problem is with the slop in the column shift while in second gear. The lever will move until it's practically in the 1:00 position but will move back to the normal position without coming out of gear. The truck otherwise shifts and acts normally with no evidence of binding between first and second gear.
Thanks for your advice.
rx
Old Apr 19, 2015 | 08:29 AM
duhrbroc's Avatar
duhrbroc
Originally Posted by rexblue
Good morning.
rx
I had the same problem. My solution was to replace both the shift collar and the shift lever. The holes in each were wallowed-out and causing the slop.
Good Luck!
RadioFlyer84
Jun 26, 2011 08:33 AM
starrider
Sep 6, 2010 09:15 AM
JoeVR5
Aug 12, 2010 10:37 PM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
