At a crossroads
Old Aug 24, 2019 | 07:14 PM
  #31
Carlosfj80's Avatar
Carlosfj80
Originally Posted by Restlesswildman
The coolant isn't an issue, unless you were running the Ford gold coolant before. If so it is a recommended to do a coolant system flush to remove the silica residue. As for the fan, are you getting above 225 F while towing? The roaring fan usually shows up around that temperature.
Thank you!
Max I hit was 219 F so that makes sense.
10-4 on the coolant, I believe it was flushed.
Freskan6.0
Jul 16, 2017 06:52 PM
Bawbag74
May 5, 2017 08:29 AM
mdelfunt
Oct 20, 2015 09:04 AM
Per4mance
Mar 31, 2013 07:59 PM
mylesdixon
Feb 11, 2009 10:23 AM
